Question about Sony RM-Y135 Remote Control
Sony Model RM-YDO10 TV remote Volume and channel keys quit working after deteriorating operation. you could only get volume to work by pressing very very hard. Now channel is doing the same.
3 Suggested Answers
SOURCE: REMOTE CONTROLER RM-YDO10
remote controler car that uses gas
Posted on Apr 10, 2009
  • 8457 Answers
SOURCE: TV remote RM-ED002 for main TV works fine except volume
Ur remote is damage,must have a new one or live with the prob.U can buy a exact one on the 1-800-Remotes Factory Original website.
Posted on Aug 24, 2009
Sony universal remote won't control the volume
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ320 Try the above Sony web site, where they have support, or call a Sony Dealer. http://store.sony.com/-cms-page.sony.authorized.dealer.list?XID=M:accessories:esupport
Nov 17, 2013 | Sony RM-VZ320 Remote Control
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
I have a chunghop universal remote, RM-133E and i need the 3 digit code for an LG tv please. Thanx.
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
Jul 01, 2009 | Universal Remote Control Remote Control
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Volume buttons of Sony Remote control is not working for Akai TV.
Volume buttons on Sony remote will work on Sony TV only.
Aug 04, 2008 | Sony RM-V310 Remote Control
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Olevia 232 hd tv remote codes
this code dd not work with my remote for the olevia 232v..
maybe i will just buy a new remote for $29.00 and be done with it...; > (
Dec 07, 2007 | Olevia LT32HVM 32 in. LCD Television
Nov 15, 2007 | Sony Televison & Video
Sony RM-Y135 Remote Control Logo
326 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
