Question about Dremel 400 - 6/90 Series Xpr Kit
I'm trying out my dremel for the first time, and can't remove the attachment I've been using.
  • 2,176 Answers
Suggest that you go to Dremel.com and download a owners manual for this tool. They also have a toll free tech number for assistance listed there.
Posted on Sep 21, 2009
2 Suggested Answers
memturbo
  • 226 Answers
SOURCE: Cannot remove attachments
your lock mechanism has worn out
I use a small drill bit towards the end of the rotary tool where
the air fins are and insert the drill into the fins to lock it down
then use the wrench to loosen .
make sure it's unplugged and don't be too forceful
Posted on Mar 27, 2009
Attach a pressure foot
Did you buy a universal foot switch or one specifically for a dremel? Many times the universal ones should plug into the wall and whatever device you connect to a plug housed on the pedal to operate by pedal. If it is Dremel specific, check the support portion of their website or try sending and email to them using the Contact Us link on their page.
Dec 02, 2014 | Dremel 1830 120V 18" Scroll Saw
I need someone to tell me how to remove the entire attachment bit from the tool
dremel have a collet adaptor available to allow interchange of bits. They are available from dremel or hardware stores.
Feb 07, 2013 | Dremel Variable - Speed Multipro Rotary...
How do I attach the flex shaft. Given to me by someone who hasn't used in a while and I just purchased a Dremel rotary. She did not have a manual with it.
You remove the bit you were using and connect using existing collet, just tighten and go.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 04, 2010 | Dremel 225 Multipro Flex - Shaft...
Help. Cannot remove the nut on the dremel
HELLO ,you must keep your thumb on the push button while trying to loosen the nut it sounds like your pushing the pushbutton in and then letting it go as you try to loosen the nut , i also have a dremel and i made the same mistake when i first got my tool , Hope this truly helps you get it off , I thank you for letting me try to help you Sincerely Glenn
Mar 04, 2009 | Dremel 400 1/6 120V Xpr Rotory Tool...
Trouble Changing Attachment
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Oct 03, 2008 | Dremel Mini - Mite Cordless Rotary Tool
Dremel rotary tool removing shaft of attachment
They can be stubborn. I would take padded pliers to the nut, and not focus on removing the shaft until the nut is loosened. Be careful not to damage the nut. You may also try spraying a light lubricate at the base of the nut and hold the dremel upside down so that some could possible get behind the nut.
Sep 27, 2008 | Tools & Hardware - Others
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Dremel 400 - 6/90 Series Xpr Kit Logo
103 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Sheldon Dedek
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
