Question about MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55)
I have a problem installing windows XP pro. I have a new 300GB ATA/133 Hard drive brand new. When I start windows XP PRO i get amessage setup cannot copy the file dbgeng.dll
  • 2,404 Answers
Make sure your dvd drive is good as well. The laser can go weak in those. Also make sure your cd is good and has no fingerprints on either side and if its a copy make sure its a good burn of it or else that would give you an error as well.
If you know the cd is in good shape I would try using a can of air and blow some gently into the drive to make sure no specs of dust or dirt are in the way of the laser cause that can cause errors. You can also always use another windows cd as well if you can get one.
Posted on Jul 11, 2009
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Installing new seagate pata/100 hard drive and belkin ata/133 controller
There should be a tab on the back of the actual hard drive where you can switch it to CS "cable select", You just take the tab out of the slot that it is in and switch it to where the cable select is. I am sure that the drive is set to something different or it would be working.
May 24, 2008 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
HP NC6000 system recovery
you have to get the cd.and please note you install the xp home first than xp pro
Apr 21, 2008 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55) Logo
128 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
