Sewing Machines Logo
A
Anonymous Posted on Jul 16, 2015
IT IS NOT SEWING IE IT SEEMS TO JUMP OR LEAVE OUT STICHES
Natasha Subko
Level 1:
Habit-Forming:
New Friend:
  • Contributor 64 Answers
  • Posted on Jul 18, 2015
Natasha Subko
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
11604
Points
81
You may be using the wrong needle for your machine or wrong needle with wrong type of thread with wrong kind of fabric.
WHAT IS THE EASIEST WAY TO UNDERSTAND A CROCHED PATTERN DIFFRENT STICHES
Search the internet for:
crochet (and then input the stitch code, ie HDC)
There will be multiple web sites and videos that explain how to make that particular stitch. You can also search for beginner crochet instructions.
1helpful
2answers
My zu2-b612 is good on other fabrics but its not good in cotton....
adjust the needle thread tension for different fabrics and thread sizes
1helpful
My elna 7000 sewing machine speed all of a sudden is very slow, does not work in reverse, or does not want to make any stiches? What can be wrong?
Looks like this is a mechanical machine. If so, bet it needs a good cleaning and oiling. The following may be helpful:
It was working now it seems to be frozen the needle part wont move
Definitely get some good quality sewing machine oil. Sounds like the machine has basically seized, including the stitch selectors.
Machine will not engage in any other stiches except straight stiches
Remove the power cord then plug the unit back in. This should fix the problem.
1helpful
I have a White 2037. The tension seems to be off. Small stiches then a large large space
Rethread the machine and change the needle. IF that doesn't do the trick then your timing needs to be adjusted.
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
White 1760 skips stiches...
Change your needle and use a ball point.
1helpful
Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do. [email protected]
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
