Question about Canon PowerShot A520 Digital Camera
Camera says lens error, restart camera
Was in process of taking a picture and my camera stopped, screen went black. at bottom of screen was a message that said lens error, restart camera and the lens will not go back into the camera. I've replaced batteries, taken memory card out and put back in. No matter what I do my camera gives me the same message. Its only 1 year old also. The camera is a Canon power shot a470. Thank you.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Lens error
It could be dust, or it could be other things. Try the procedure in this tip.
Jun 16, 2012 | Canon SD4000 IS IXUS 300 HS Digital Camera
I press the ON button and its a blank black screen. Then it beeps and says Lens Error. Restart camera on the bottom left corner.
Hi.
This message could mean that the camera detected an error while retracting the lens and has automatically turned off the power.
It can happen if the lens is pressed while it is moving, or if it is jammed e.g. by debris or sand. It may be cleared by switching on again and reviewing images or taking pictures.
You might find the cost of professional servicing to be uneconomic so if all else fails you could try gently waggling the lens or taping on a vacuum to try to dislodge anything which is causing the lens to stick.
You can download the 'reference guide', which is the full user manual, here:-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Regards
Jan 19, 2011 | Canon PowerShot SD600 Digital Camera
Canon sx200 is, lens error restart camera, after taking some pics I wanted to delete them, so after deleting one picture I've got black screen and the message "lens error restart camera" and the camera...
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Canon Cameras
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
First a black screen, then a lens error
For the lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Oct 23, 2008 | Canon IXUS 860 IS Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens
Switch off and on again? Take battery out and replace. Thats the only 2 ways of 'restarting a camera that I know of. Does your model have a 'reset' function? You will have to check the manual for that. Or ask Canon support.
Aug 22, 2007 | Canon PowerShot A460 Digital Camera
Canon PowerShot A520 Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
