Question about Acer Aspire 3610 Notebook
Acer aspire 3634 LMi
There is power being supplied to the laptop ( indicated by the green light ) yet the laptop wont turn on when tou press the power button. any help would be apriciated. thanks
  • Anonymous Apr 17, 2009
    Acer laptop 3610 will not turn on, but battery light indicator is on when power supply is plugged in
Have had a similar problem with my 3634.
I was advised to disconnect from the mains and remove the battery. I then had to depress the "on" switch for about 10 seconds. I then reconnected the mains lead and away it went.
Apparently if your battery is a bit "iffy" it can cause the whole thing to shut down even when on the mains.
Hope it works for you - let me know.
Cheers!
Posted on Nov 19, 2007
    Novelist:
  • 85 Answers
Do you get any beeping or flashing status lights when you try to start it up?
Posted on Nov 16, 2007
My laptop will not turn on or charge
Check your power supply to make sure it is still outputting the correct voltage.
Aug 27, 2014 | Acer Aspire One PC Notebook
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Budi
http://www.laptops-drivers.com/acer-notebooks/download-driver-acer-aspire-4315-for-xp-or-vista.html
copy the above lines into address bar go there check the sound driver download install tou must uninstall any older sound drivers
Jul 27, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 3610 Notebook Logo
481 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
