Hi
Your projector has 3 lights:
Is only the Power / Standby LED flashing green and then turning red?
Thanks
nLinked
Thank you.
The flashing green means that the projector has just been turned on, but is warming up. This is normal. When it turns red, it means it has entered the standby state and is either waiting for you to plug in:the power cord
or the video cable from a device like a laptop, VCR, or whatever you want to project an image from
So basically, it's waiting for an image from a device.
To get it to project something:Remove the lens cap
Ensure that the power cord and signal cable are securely connected. The Power LED will be red.
Turn on the lamp by pressing “Power/Standby” button either on the top of the projector or on the remote. The Power LED will fash green.
The startup screen will display in approximately 10 seconds
The frst time you use the projector, you can select your preferred language from quick menu after the startup scree display.
Turn on your source (computer, notebook, video player, etc.). The projector will detect your source automatically.
If the screen displays “No Signal”, please make sure the signal cables are securely connected.
If you connect multiple sources at the same time, press the “Source” button on the control panel or direct source key on the remote control to switch between inputs.
Hope this helps.
Best regards
nLinked
What is the device you are connecting the projector to (make and model)?
Did you turn the device on and still get no picture through the projector?
Finally, if you turn on the projector and point it at a projector screen or wall without connecting it to any device, does it boot up and display the brand logo on the screen, or does the bulb not even light up?
yes the power/standby light.
no im stil having problems with it i did what you told me to but it still showing me red light it doesn't stay to green.
my laptop is acer-aspire 5735 . i don't see nothing on my wall no logo or nothing bescally when i plug it in is red when i turn it on it flashes to green th fan turns on and i don't see nothing on my wall then after 30 sec it turns back to red again.
