Question about Raypak Pool & Spa
My raypak pool heater does not work. it gives an error I LO. What does that mean?
  • 2,418 Answers
You have one leg of the 220volt power off line, it's a breaker or a fuse, or just a broken wire to the panel.
Posted on Jul 11, 2009
What does code 'ILO' mean and how do you fix iy
ignition failure tried 3 x didn't light lo high limits bad
Jun 22, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypack 2100......cfh then spark after a few moments.....what appears to be :Lo.....what could this be
check gas pressure sounds like too small meter especially if furnace or dryer is running call gas company give them added value of all gas operated appliances
May 24, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
What does this code mean? :LO
check pressure switch or copper tube to it
May 22, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Pool heater says lo
Say "lo back! Sorry about that. Can you give me a little more info about indications? Has the filter been cleaned lately? A dirty filter often will restrict the water flow enough to where the heater thinks that the pump is not running.
If there is doubt jump the pressure switch inside the heater and if it fires you have a dirty filter or a bad pressure switch.
Jul 04, 2013 | Raypak Pool & Spa
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My raypak heater has error code LO. What does that mean
This is in the limit string. This is the string of safty switches in the heater. (thermostat, highlimits, rollout switch and pressure switch) The pressure switch is the most common problem. If the water flow get's to be too little so the water inside the heater is going to overheat than this will shut the heater down. This can be caused if your heater by-pass is to far open and letting water go by the heater. The most common problem is clogged baskets or a dirty filter. Other than this you can follow the flow chart in your manuel to find the source of the problem but if it just started without obvious cause this would be my bet.
I hope this helped and good luck.
Aug 31, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Pool & Spa Logo
50 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
