Question about Vizio L32 32 in. LCD HDTV
The component side of my vizio 32 plasma is not working. tv says no signal no matter what i hookup to that side of the tv. the av side works fine. whats the problem
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside that needs to be replaced. In many of these newer TVs you won't find all of your inputs on the same internal circuit board. This way each is more secure and if one fails, they all don't fail. The board that has your component input on it needs to be repaired or replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 11, 2009
  • 3 Answers
Mine is gone out too, amazing they last a year and then go.
Posted on Jul 27, 2009
My vizio remote works but the tv doesn't respond. I replaced the remote anyway but it still doe not work. resetting tv doen't work what is next?
It is possible the remotes are either bad or not compatible to the tv. Recheck the remote type and the batteries to see it that helps.
Feb 21, 2015 | Vizio L32 32 in. LCD HDTV
I have a tedelex plasma tv the model of the plasma is ec pd300 . on any in put the plasma says there no signal
if any of the component input doesn't work or not recognized a source the cause will be a bad signal input board. check for bad component like open resistance and burnt parts.
Aug 17, 2012 | Televison & Video
I am trying to connect my mp3 player to my Vizio VX42L
In most cases the TV's have a "video mute" feature that will block the audio until the set detects a video signal in the corresponding video port. You either have to have a way to turn the video mute off or run a video signal into the video input that corralates with the input you are wanting to connect your mp3 palyer to.
Jun 29, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VP50hdtv10a problems The "TV" mode, I can only hear sound. All the channel are black and white dots all over The "DTV" mode was working and now is gone after we installed a new cable box today The...
If you still have audio and video from component and RGB which means your sustainer boards (the boards on the two sides that powers up your screen) are working. All you have to do is replace the main board. you can buy parts at Vizparts.com, Vancebaldwin.com or shopjimmy.com. Make sure that you give them the correct model and serial number so they can send you the correct part.
Jun 23, 2009 | Vizio VP50 10A 50 in. Plasma TV
50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 17, 2009 | Vizio VP50 10A 50 in. Plasma TV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
Nov 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
591 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
