Question about Imperial IFS40 Deep Fryer
The pilot light is on but when the dial is turned nothing happens
    Problem Solver:
  • 3 Answers
Make sure pilot flame is in full contact with thermopile
Posted on Jul 18, 2009
SW4P won't light
Sounds like ignition problem check earth & power. If your getting a spark check pilot assembly
Apr 20, 2014 | Suburban 3 gallon Water Heater Pilot Sw4P...
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Hi there i recently had another gas appliance installed and the gas was turned off while this work was done, so my hot water service pilot light went out. the guys who did this work didn't relight the...
First turn the dial on the hot water heater to the off position and wait for 5 minutes. Then turn the dial on the water heater to the pilot position. Press in the dial and use a gas grill lighter, long wooden match, or similar device to light the pilot. Once the pilot is lit, continue to hold in the dial for about 1 minute then release and turn the dial to the temperature setting that's comfortable for you.
Dec 11, 2010 | Heating & Cooling
We have an older (22 years?) 'Insta-Flame (model HE30 TN) natural gas fireplace insert. The pilot light is out, as we painted to inside of the firebox. The instructions show to 1) turn the dial to 'off'',...
On some gas valves the pilot setting is on the same dial as pilot on and on .on others the pilot light has aseperate button on right side of control dial. If yours has this there will be a cut out on cotrol dial that must be aligned with button to allow it to be depressed to light pilot. If yours has this align control dial cutout with pilot button,depress button and light pilot,hold for about one min. and slowly release,if pilot light stays lit,turn down thermostat and rotate control dial normally to right . There should be arrows or marks on dial and gas valve to line up. If pilot light stays lit turn dial to next position and check to see that pilot is still lit. This should be on position, turn up thermostat and burner should light. If your dial has pilot light setting on it then rotate dial to each position,try to depress dial and when you have right one dial will depress allowing you to light pilot. Follow same procedure as above and you should be in business. Hope this helps.Thank you
Nov 11, 2010 | Heating & Cooling
This fryer has been giving us problems. After we
You can try putting a jumper wire between the two terminals on the thermostat after the pilot is lit to see if the valve comes on. It is less than 1 volt so don't worry. That will tell you if the problem is with the thermostat or the gas valve.
Tom
May 18, 2010 | Dean SM20G2 Deep Fryer
When dial of oven is turned on, nothing happens.
Have you checked the pilots for the oven? If the pilots are lit and it still isn't working then the problem may be the gas valve.
Mar 06, 2010 | Whirlpool SF310PEK Gas Kitchen Range
Honeywell propane relay won't start
For the pilot you have to hold the red button down for about a minute or two while it is lit, then turning it to on. If you tried this and it still wont stay lit then you can try replacing the thermocouple. For the relay the best way to tell is take voltage reading to see if the coil is getting voltage across it.relays are usually inexpensive,and easy to install.Just be sure to turn the power off befor touching the wires,and mark them so you know which wire goes to what terminal.
Mar 07, 2009 | Frymaster Dean 2424G Deep Fryer
Starting a Regency fireplace: gas is on, I turn the dial to pilot. I am suppose to push the dial in, spark the themocouple and hold it for 30 seconds. My problem is that the dial doesnt push in. The only...
Can you spark it and does it light in the "off "position? Try it and see if when the pilot stays on, you turn it to pilot and the burner ignites.
Sep 18, 2008 | Heating & Cooling
Imperial IFS40 Deep Fryer Logo
95 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
