well why not check the voltage to the blower on high.
not 12v, then controller is bad.
if 12vdc is good the blower is bad.
easy peasy japanessy. (oops Korean South)
but Koreans are disgruntled Nipponese. LOL
the FSM shows how to remove it. ever seen one?
the Factory service manual.
or log in to alldata.com and just read that?
Hyundai VSS locations: On 1999-2003 vehicles, the vehicle speed sensor is built into the
speedometer. On 2004-2005 vehicles, the vehicle speed sensor is attached
to the output shaft of the transaxle.
On 1996-2003 vehicles, the
vehicle speed sensor is built into the speedometer. On 2004-2005
vehicles, the vehicle speed sensor is attached to the output shaft of
the transaxle.
built into the speedometer. On 2004-2005 vehicles, the vehicle speed
sensor is attached to the output shaft of the transaxle.
no valet switch,you will have to replace batteries/keypad to make it work and you CANNOT bypass the system......otherwise whats the point in fitting it??
1) Is switch on low and STILL blower is on high? OR,2) is it not working UNTILL you put it on high? Start with replacing switch, if that doesn't work, think about replacing blower, or get used to it on high. Switch is an inexpensive start to resolving the problem.
Inertia switch is located in one of two areas, on the passenger side panels next to the toe kick by the radio. Or up under the dash. It will be a red button that you need to puch in
