Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Cant turn fan on with out turning the light on
I have a problem i cant turn fan on with out the light being on
    Brigadier General:
  • 4,088 Answers
Fan power is wired to light side of light switch. Move fan wire to other side of light switch.
Posted on Jul 12, 2009
I can't turn off my ceiling fan. Remote batteries are new. Fan not connected to a switch
need to disconnect the power source to fan then test the transponder / relay in fan possible faulty and will probably need to be replaced
May 06, 2018 | Hunter Dryers
How do I replace the light bulb on ceiling fan for Airworks. Can't twist it off!!!
Try putting on rubber gloves and turn the globe clockwise. The globe has a very smooth surface and is impossible to turn with bare hands because you cant get a grip on it.
You can read the whole forum below:
Replacing Ceiling Fan light bulb PhD required
Nov 16, 2016 | Dryers
I cant cut my new ceiling light off from my wall switch aftetreplacing ceiling fan what should I do
What is make/model of fan. How do you change speeds(wall control,remote,pull chain) & how do you turn light on/off?
Oct 30, 2015 | Dryers
Turn of century ceiling fan troubleshooting
Make/ model of fan please! fanman9952@aol.com
Aug 25, 2014 | Dryers
I have a futura Model LD140129L-SL ceiling fan and light, 4 Blades, steel and the light is Ceramic I think.I cant for the life of me work out how to take the cover off to change the bulb.
The white glass turns independent of the silver surround in an anti-clockwise direction about one quarter turn, that is the direction the fan spins in the summer direction, pushing air down. It has three metal pins that fit into tapered slots in the glass cover. Once it has turned it should drop down. If it is stuck, get your safety glasses and a small hammer and just smash the bloody thing, when you buy a new bulb, buy a new light cover.....
Owen In Oz
Jan 14, 2011 | Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Beeping fan
yes, you can take the little,(cant remember what it is called) out of the circuit board in the fan itself, if you do it yourself please remember to turn the power off! if you know a electrician,hey should probably be able to tell you what it is that makes the beeping noise.
Nov 12, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
I cant get it to turn on
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 23, 2008 | Jenn-Air ® 48" Professional Over The...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
110 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
