Question about Canon CanoScan 4200F Flatbed Scanner
"Noise" on scanned photographs
When I scan a photo on my scanner horizontal lines (usually two or four) of various colours have started to appear on the pictures. Is there a solution?
  • Barbara Clark Jan 25, 2008
    At first, the lines would show up just when I scanned a large photo or document. Now, they're showing up even for everything I scan. It is not a glass cleaning problem, but I can't seem to figure out what's causing it and how to fix it.
  • Anonymous Jun 01, 2008
    Regardless of what I try to scan, I just get a series of vertical coloured lines.
  • Canon Master
  • 2,022 Answers
If you are able to open the cover of scanner glass then pls clean the glass and see.
Posted on Nov 16, 2007
Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
  • Turn on the computer and thescanner.
  • Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
  • Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
  • Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
  • Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
  • Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
  • Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
  • Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
  • Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
Sep 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Re. HP ScanJet 3970 Flatbed Scanner Horizontal lines.\r\n When I scan, I get light coloured lines approx 2mm apart across the complete scan, which show up primarily on the dark colours. Different...
Hi! I had a same issue with another HP Scanner model. I was not able to repair, so I ask my company to buy a new one. I know that it can be repaired as ething can, but as I undertand this issue occur as the head of the reader is not scrolling in the glass as expected and it can be for differnt reasons or power supply is not work properly.
Have more success,
Nov 19, 2010 | HP ScanJet 3970 Flatbed USB 2.0 Color...
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
On preview & scanning I get total red colour image
If you have loaded Adobe 8.X Reader, then unload it, and go to Adobe site and load Adobe 7.02 Reader. Problem will probably go away. Mine did, I can now scan in color again.
Dec 03, 2007 | Umax Astra 3400 Flatbed Scanner
Scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Oct 07, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
Canon CanoScan 4200F Flatbed Scanner Logo
223 people viewed this question
old marine
old marine
