Epson Stylus C43SX InkJet Printer
Problem for Epson Stylus C43SX InkJet Printer
C43sx both lights on
By jersel on Nov 15, 2007
Turning on the printer, the head moves a little bit to the left then red light on (not blinking). Pushing paper/ink button , head move to left again.... and again.... and again. Replace new Ink cartridge both black and color same problem. Counter reseting.... not work. Any idea?
thanks jez
Comments:
Nov 17, 2007
- I found the cause of the problem thanks.
Same Problem
Apr 07, 2009
-   same problem with my c41ux. Hopless brand I guess, will buy a canon next time, i had an old one with no issues, dont know why i upgraded to an epson if everyone has this same problem without any help-   Guest
Aug 17, 2008
-   my printer is c41ux... still when i turn the printer on, both the red and green is turned on.. the green light is blinking while the red light is not but both are or.. and i cant print..huhuhu.. hurry.. -   Guest
Jun 26, 2008
-   when i turn on my printer, green and red lights are on (not blinking). when i press the paper load button, the printer head moves to the left, the state when you remove and change the ink cartridges. when i press the paper load button again, the head return to the right and as if it performs the cleaning process. i can't print. my black ink cartridge still has ink and the colored one had just been refilled. thanks for your help. -   juicewah13
Jun 19, 2008
-   in epson cx43sx printer power on, red light on
-   Guest
Jun 17, 2008
-   I have a problem with the red light and the green light on, so i can't print. It said I must have contact my technical support to reset the printer and the spareparts. And it must be took 2 - 3 days to repair it, but i can't take any longer to use it. Please give me solution to repair it on my own quickly. Thank u. -   lily_marly
Best Solution
posted on Nov 20, 2007
Helpful)
vince2285
Rank: Apprentice
Rating: 87%, 7 votes
my printer epson stylus c43 series have a problem... the red light was blinking....
Was this helpful?
Yes
No
Solution #2
posted on Nov 16, 2007
Helpful)
rwedinburgh
Rank: Wiz
Rating: 85%, 98 votes
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
Was this helpful?
Yes
No
Solution #3
posted on Jun 23, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
are madhacho hp driver kya hua
Solution #4
posted on May 11, 2009
Not Rated)
gwbm
Rank: Guru  Epson Expert
Rating: 89%, 163 votes
Hi Guest of Apr 7 2009. It is not a good idea to add your problem to such an old (and probably forgotten) other person's problem. Join Fixya, start a new post with details of YOUR problem and you will get attention from the Fixya team of helpers.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus C43SX InkJet
Questions and Unsolved Problems for Epson Stylus C43SX InkJet
Do you recommend Epson Stylus C43SX InkJet Printer?
Answer
Answer
The printer c43sx cartridge aren't moving properly bothside tell me how can i slove this problem
Answer
Hi, I have Epson C43SX printer; I did not use the printer fro sometime. I changed the Cartridge; but... (More)
Answer
Epson Styus color 440 i just replaced black ink cartridge, printer goes thru all the motions but... (More)
13 Other Users Have The Same Problem - Continued
Comment by carla_ley, posted on May 29, 2008
both the green and red lights are blinking...my printer is no longer able to print...wats wrong?
Comment by sarj_88, posted on Apr 02, 2008
when i turn on my epson stylus c43sx, the red light will also turn on and the head moves to the left. after pushing the paper/ink button, the head will just move either to the left or right and the red light does not turn off, it's always on. because of this my printer does not print.what should i do? what's wrong with my printer?
when i turn the printer (Epson stylus c43sx) on, the red light also turns on. then the head moves a bit to the left. after pushing the paper/ink button, the head will just move either to the left and the right again and again. what should i do? what's wrong with my printer?
Comment by Guest, posted on Mar 15, 2008
power on[green]blinking.red button not blinking but always on.does not print what to do?
Comment by tabuge, posted on Feb 27, 2008
red and green light is on but not blinking, not printing
Comment by IDKHAN, posted on Jan 17, 2008
EPSON STYLUS C43SX Ink Jet printer: When I turn th printer on , the head starts moveing and moving to right untill it reaches the right edge of the slider. at that point red light turns on and the head tries to move right and right .Since there is no space to move further right it creats a cranking sound .At last the printer turns off after 2 to 3 inutes.
Please guide me
M A khan
Comment by Guest, posted on Dec 29, 2007
everything else seems ok no blinking lights green and red but no printing plz help
Comment by Guest, posted on Dec 26, 2007
Have problem same with this, i have clean the ink tank, the problem is same the red lamp still blinking. and we have been using this printer since 2004 year ago. And trying to reset the counter but still quite. any idea please?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
