Question about Polaroid FLM-2601 Television
Won't power on
I had the same problem and i replaced the capacitors also, when i turned it on the capacitors started smoking. lol i had the polarity wrong. tried again and it worked. my t.v. has been up and working for the last six months. but the t.v. is giving the same symptoms as last time like the caps might be going bad again.this might be constant maintenance.
  • Polaroid Master
  • 8,457 Answers
U need a hold board to replace or some else will burn alway domino effect.
Posted on Aug 17, 2009
Which one is the capacitor
Posted on Aug 13, 2009
Picture was fine sound was fine suddenly white smoke and a gentle hissing sound emerging from the top of my sharp lcd 40" can anyone diagnose the issue pls
The white smoke - usually with a nasty smell will be a capacitor in (most likely) the power supply section. You will probably find one of the capacitor cans has a bowed and punctuered top. It's designed to fail that way with excess pressure. (If the top hadn't punctured, then the pressure would probably have blown the entire can off of its legs and made a mess on the PCB.)
Assuming it is a failed capacitor, it's probably a one-off (you'll find out!), so replace it like-for-like. Pay attention not only to the polarity and voltage rating, but make sure it is high-temperature rated (ususally 105C) and a low ESR type. Fittting a standard (non-lowESR) capacitor in a switch-mode power supply will lead to early overheating and failure.
(Obviously, if there's any detritus from the old capacitor, clean it off of the PCB first!!!) Good luck with that.
Dec 02, 2016 | Sharp Televison & Video
Was smoking. Took back off and found a capacitor where it was coming from. Can I remove it without having to replace it?
No Walter
That capacitor is there for a reason.
It MUST be replaced with an electrically identical one but before doing that, I'd certainly want to know the reason why the smoke was let out of the original.
-Steve
Apr 17, 2015 | Televison & Video
MY SAMSUNG 52" LCD TV IS VERY SLOW TO TURN ON WHEN COLD.
If this is an lcd tv check for capacitors on the power board that have domed tops. Replace these capacitors with the same value. microfarad mf and voltage v. make sure to notice the polarity and no not us non polarized capacitor. only use electrolytic capacitor .
May 30, 2013 | Televison & Video
Toshiba 19w330db was coming on until i change acap on little board from330uf 25v put in 440uf 25v now no power
Replacing a 220Mfd capacitor with 440Mfd wond poise this problem. Just check, whether the the polarity of the repalced capacitor have been reversed. Electrolytic capacitors have both +Ve and -Ve terminals. It reversed, the capacitor will insert a short circuit, when you switch ON the set. On some occations, it will heat up and will burst out. Check this first. The polarity of electrolytic capacitors will be marked on the printed circuit board too. Check whether the markings at the printed circuit board matches with the polarity of electrolytic capacitor you have recently replaced.
Jun 11, 2012 | Toshiba Televison & Video
Monitor wont turn on
Usually the capacitors are 1500uF/25V and 470uF/25V, but I suggest to use 35V capacitors. This will make your power supply to last forever. Also, you better open the monitor and see by yourself what kind are the capacitors. Mind the polarity or the capacitors will blow out with lot of smoke. You can buy them from local parts store like Conrad.com or online.
Apr 07, 2012 | Samsung Computers & Internet
DX-PDP42-09 Won't power up. There is clicking for a few seconds, then led 2 starts blinking. The screen flickers and the red power light comes on. No picture, no sound. Which board do I need to...
Sir before replacing the board try to check first the power supply, this fault is commonly cause by bulging capacitor or leaky capacitor, this bad capacitor is producing a low and unfiltered dc output that causes your unit to malfunction.
This is the bulging capacitor if you see this replace with the same type and observe polarity, capacitor is much cheaper than the whole power supply board replace this and it will fix the problem hope this help good day and best regards.
Sep 21, 2011 | Televison & Video
The Chrysler voyager has sat on the drive for a couple of weeks and now won't start, totally dead. When we tried to jump start it started sparking and smoking as soon as they were connected to the...
Look inside the voyager and make sure that everything is turned OFF... Since the battery was completely dead there could be something that was left on and this is creating a big load when you try to connect the jumper cables.
Double check your polarity on the jumper cables and try again.. If you have the same problem, I would suggest disconnecting the voyager battery and trying to charge it with the van disconnected. Batteries can do some strange things.. Best of Luck to you..
Aug 18, 2011 | Chrysler Voyager Cars & Trucks
LG tv won't turn on. No power at all.
This trouble is very common for lcd if you remove the back cover of your tv try to look for bulge up in the top of the capacitor or not perfectly flat like the others or if you see something with a wet mark at the bottom of the capacitor try to replace them but be sure to remember the proper position of the capacitor because it has a polarity, When this capacitor has a bulge up or leaky it will not properly filter the dc voltage and it cannot transfer properly the dc voltage to other parts. Note be sure to unplug your unit first before removing the back cover, good day and best regards. Feel free to send feed back.
Jul 25, 2011 | LG 42LC2D 42 in. LCD HDTV
Solex SX-10L guitar Amp. guitar was plugged into the headphone socket by mistake and it started to smoke.The 500ml amp fuse did not blow. can you help? I have replaced two resisters. 35v 2200uf and a 35v...
The passive components are smoking because there is a short in the drive. Hence you will need to do a voltage check to see the point of power drain and change the transistor or IC which had failed in this wrong switch over. You dont have to panic as you can do it with a little bit of patience and logic. trace the low continutiy of the voltage in this section and isolate. Please see that the polarity of the capacitors replaced is correct. Try to trace the cirrcuit near to the smoking and disconnect the stages close to it to confirm and identify the fault. Hope my advice helps. Good day
May 26, 2010 | Audio Players & Recorders
Polaroid FLM-2601 Television Logo
116 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
