I have a renault megane 2004 and the ac cooling goes to nil after couple of weeks from the time I fill the gas.I recently checked and the guys told me that there is absolutely no gas and have to replace the whole thing.The blower works fine and I get hot air..lol.But the no cooling.So I keep my windows open and drive.Please help.
It seems no one has tried to find a leak, should not refill without leak checking. Where there is a refrigerant leak, some residual oil will appear, refrigerant and oil circulate and move together. The system should be cleaned so that any new oil leaking will mark the leaking area or spot when leak testing produces nothing. When no leaks are detected, a dye can be used to mark the leaking area.
Leaks are common to develop on joints where seals are present and where hose is crimped to solid tubing. I don't recommend leak sealer additive into the system.
Testimonial: "Hi Jorge..Let me try these with another mechanic and update you..Thank you.."
