Question about Carrier Heating & Cooling
My Carrier Model Number is 38YKC036300. What is
My Carrier Model Number is 38YKC036300. What is the correct Low pressure and head pressure?
  • 306 Answers
68 psi and depends on the outside air temp. for the high side but around 250 psi.
Posted on Jul 11, 2009
Error E F for carrier air-conditioning
What is the make and model of your ac unit? Air Conditioning Repair in West Palm Beach Florida whats to help you, let us know.
Aug 29, 2017 | Carrier Heating & Cooling
Ac model # 42sd6b er-05 code meaning
Are you trying to run your cooling now? I'm guessing you have a carrier thermostat and that's where this is displaying. It's been awhile since I've came across one but to my vague reculiction that code indicates the outdoor sensor detects low ambient them temperatures which in turn will not allow your air conditioner to run which would make sense this time of year. If you want to run cooling in below 60 degrees temps you must add a "low ambient kit" this shuts the fan down outside to build up higher head pressure without doing this you will just ruin your ac but in your case it won't let you. Google up your Tstats model number and codes if that's not your situation.
Nov 24, 2014 | Carrier Heating & Cooling
Carrier ac keeps turning on and off
what is the temp. outside ? If it is doing it when its hot out clean the coil outside could be tripping on high head pressure. If its not make sure the inside fan blower is turning.If its not it could be tripping on low head pressure. If it only runs a short time you probably have a low charge.and it is causing it to short cycle.
Apr 18, 2012 | Carrier Heating & Cooling
The control knob on my Carrier model Vision Aire window air conditioner broke. I'd like to buy a replacement know to control the fan.
Jules, without a correct Model Number (not Vision Aire, that's just a glitzey name), it's hard to steer you in the right direction on where to find the knob. If however, you can come up with a correct model number, you can go to the link below and search for it by your Model Number.
http://www.appliancefactoryparts.com/airconditioners/carrier/carrier-knobs.html
Hope this helped you.
Jul 06, 2011 | Heating & Cooling
My carrier unit #38TKB042300 / 3794E16886 Is not cooling. The Compressor is not running. I thought maybe the capacitor might be bad so I put a new one one. The compressor comes on and runs for 3-4...
Check the running pressures and if the low side drops to low it may be shutting down on low pressure switch.I just used this as a rule of thumb. If the outside air temp is around 90 degrees then the pressures should be in the range of 60-70 on the low side.And 250-300 on the high side. If you can get the compressor to stay on then I would clean The a-coil and condensor to get maximum effiency.Thank you.
May 10, 2011 | Carrier 38CKC042 Air Conditioner
We have a Carrier Infinity 96 furnace in our home, which was installed brand new in our house we built 5 years ago and this thing is a nightmare. We've had the code blinking away and and the technician in...
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE
NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY THE NUMBER OF LONG FLASHES.
43 LOW-HEAT PRESSURE SWITCH OPEN WHILE MEDIUM-HEAT PRESSURE SWITCH IS CLOSED - Check for:
- Low inlet gas pressure (if LGPS used).
- Plugged condensate drain.
- Improper pressure switch wiring.
- Water in vent piping, possible sagging pipe.
- Stuck open low-heat pressure switch.
- Disconnected or obstructed pressure tubing.
Mar 28, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
My carrier unit is blinking 5 slow blinks and i can't find the fault codes to determine the problem. the model number to this unit is 58wav091-14
Dont know about yours, but the models we carry use fault code 5 to indicate low pressure/charge in the system.
Nov 30, 2010 | Carrier Heating & Cooling
Carrier Model 38LE048310CD Contact swith not
If you put a jumper wire across the low pressure switch and unit runs then either the low pressure switch is bad or you are low on refrigerant. Then check to see if you have 24 volts from common to Y1 at the control board,if you do then it's the low pressure swtch or low on refrigerant, if not it's the board if you have 24 volts coming into the board on Y1 and Common.
Jun 21, 2010 | Heating & Cooling
Air filter size?
You have to messure at the bottom of the air handler (inside unit) the width and the deep(from the front to the back).
Sep 25, 2009 | Carrier Heating & Cooling
I am working on a carrier package roof top unit about a 5 ton. My head pressure is a little low and my suction is double what it should be. I cannot valve off the unit to try a pump down to check txv. How...
you could always disconnect the sensing bulb and warm it up see if the pressures change or i would squirt some refrigerant in and get your head pressure where it should be and see what happens with the low side hope this will help?
Jul 30, 2009 | Heating & Cooling
Heating & Cooling Logo
486 people viewed this question
Top Carrier Heating & Cooling Experts
Donni Steen
Dennis Boxerman
1STHVACMAN
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
