The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or
blinking then the printer has a maintenance request error. It means that
the waste ink counter has reach its limit. The remedy is to replace the
waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here
http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the
key to success when you reset the counter using the control panel so
keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen.
Paper feed, cleaning button. (thr paper out light will flash for 3
seconds)
Step 2.While the paper out light is still flashing press
the cleaning button for 10 seconds. The following leds will flash in
sequence Ink out lights black and color, Paper out light. Once the
printer starts to initilize the counter should be reset. This
will reset the protection counter.
