The base attachment turns when the blender is turned But when the pitcher is placed onto the motor base, the blades do not turn.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
