Question about Neff U1721 Double circotherm Electric Oven
Fitting a new heating element Neff U1721
We managed to get the old heating element almost off but found it had wires connected to the left hand side of it, how do we get these off? Is it a simple case of just detaching them and re-attaching them to the new element? Our oven only pulls out so far so can't really access it too well from the back.
  • 13 Answers
You need to remove the element from inside the oven cavity, but it is a bit of a fiddle. Once you have removed the screws at both ends of the element you need to remove the fan blade to access the centre fixing screw. Once all srcews are remove you have to twist the element and pull forward to remove the wires from the hole on the left, then remove the wires and refit to new element.
Posted on Jul 29, 2009
My Neff U1721 element went with a bang. We have replaced before on 3 occasions successfully - but the elements have not lasted very long. On this occasion have replaced element - but not working. Please...
Hello Helen. You should not have to replace the elements often unless you are a commercial establishment using the ovens constantly. If you are commercial you may not have any thing wrong. Otherwise, I would recommend that you check the wiring that feeds the elements and those connections. If the connection to the element is loose you may be getting intermittent sparking which would shorten the life of the heating element. J.
Jul 31, 2010 | Neff U1721 Double circotherm Electric Oven
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
How do I replace the heating element in Neff U1461N2 main oven?
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
565 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
bobby1964
Level 1 Expert
Paul Carew
Are you a Neff Oven Expert? Answer questions, earn points and help others
