Question about Dell Inspiron 6400 Notebook
Switching on the laptop
My dell inspiron runs down of battery,i later realised that the power to the mains is unplug.I did plug it and does has not been responding to when i switch on the power button.
please wht is the problem
  • 37 Answers
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
Posted on Nov 15, 2007
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron N5030 Shuts Off Unexpectedly
run it without the battery just mains if runs ok it a faulty battery
Aug 25, 2017 | Dell Inspiron N5030 Notebook PC
My dell inspiron mini 10 wont power up at all with charger and only gives me a brief white light when battery and charger are plugged in. Any suggestions
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | Dell Inspiron Mini 10 Notebook
My Inspiron 1545 turns off when I unplug it from adapter, and when plugged in, the power light on front flashes four times orange and one time white repeatedly.
Does the battery for dell inspiron 1545 plug in. It maybe because the battery pack is too hot ,you can turn off the laptop,let the pc notebook and the laptop battery both cooled down.Then try turn on it to see. If still happen to the matter,it must because the wrong turn off did harm to your Inspiron 1545 laptop adapter.
Dec 16, 2010 | Dell Inspiron 1545 Notebook
My dell inspiron 1525 laptop is not switching on
unplug the power cable and take out the battery, then press and hold the power bbutton for 30-35 secs. Insert the battery and plug the power cable, check if it works!!
Oct 18, 2010 | Dell Inspiron 1525 Laptop
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Sep 12, 2010 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
My dell laptop won't turn on and the two lights
what is the pattern that these lights flash or do they just blink repeatedly?
there is a chance that you will need to replace the system board on this laptop. continually flashing lights usually are an indication of a faulty system board or power supply. with a dell, these are on the same part.
Jul 11, 2009 | Dell Inspiron 8000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Notebook Logo
55 people viewed this question
Alun Cox
