Question about Kodak EasyShare M1033 Digital Camera
It will not stay on!?
Similar problem as above
    President:
  • 2,761 Answers
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
I want to van camp in my Transit 2014 - with the doors open -
Hi Jene, there should be a 3 way switch above the rear view mirror to control the lights. The 3 positions are 1.all the way over to one side = Off, 2 in the centre position = Door Open & 3. all the way over to the other side = Always On. There may be a similar switch at the centre dome light. Also have you waited for the light to go out? sometimes these lights are on a time delay.
Trust this helps, regards Alan
Apr 12, 2015 | 2014 Ford Transit Connect
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
CD's won't play. The counter stays at "00" & the LED light above the play buuton stays off.
I never have trouble playing CDs on a similar Crosley system, but you might want to first try playing a disc that you purchased at a store. It may be possible that your system cannot play some formats of burned discs.
Apr 12, 2011 | Crosley CR-74 Shelf System
Low coolant light stays on. Changed sensor. Still comes on. Tech says oil leaking into coolant contaminating sensor. Says this is a common problem with this car. Is this a head gasket problem, and will...
I had a similar problem. Replaced head gasket, but low coolant light stayed on. My problem was air in the system. A flush and fill kit may work, however, I had a local shop do a "flush and fill" and the problem remained. What I did... With vehicle running, and radiator cap off, bring engine to operating temperature. Increase rpms slightly above idle until coolant can be seen moving in radiator (thermostat open). Add small amounts of coolant, keeping the radiator level just below overflow hole in cap area. In my case, after about 15 minutes at slightly above idle rpms, a large pocket of air escaped. I topped off radiator, installed cap, and let engine cool. Problem has not returned in last six months. *Note coolant is VERY HOT, and if rpms fluctuate, coolant will expel quickly from radiator. Also, when the air pocket escaped, coolant also sprays out. Use caution to avoid being burned.
Feb 01, 2011 | 2002 Buick Century
TV looses picture and sound. Will not turn back on
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set. I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
Apr 28, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Mouse jumps around doesn't stay on stop you want it to.?n I'm playing bejeweled blitz and when I go to a cube to move it sometimes goes above or below the cube. Won't stay on it.
Try getting the software called Mouse Doctor, or a software similar to this. And it will diagnose to see if there is any calibration error in the mouse, if there is, it will either fix it or recommend what to do to fix the problem. Hope this helps.
Good luck. Message me if you have any other questions.
Jan 03, 2010 | Logitech 9311570403 Mouse
The sppeedometer is stuck 40kmph above what im doing and stays at 40 when i shut it off the oil guage does a similar thing
Sounds like you have a instrument cluster problem first thing you could do is take it to your local dealer and have them sweep the gauges with there tech2 if this doesnt fix it have them drive it with the scan tool on it and see what the computer is reading while driving down the road.
Dec 20, 2009 | 2003 Chevrolet Silverado 1500
WE HAVE A VULCAN GAS SPACE HEATER AND WE CANT GET THE THE PILOT TO STAY ON.
make sure the thermocoupler is in the tip of the pilot flame. Thercouplers fail and when they do they cut all gas off.
Jun 08, 2009 | Heating & Cooling
Needle guide has come off
I believe I had a similar problem. I called brothers and he solved it for me.I could not get the needle clamp to stay on.There is a little allen screw in the block right above the clamp screw. I loosened that,put it on the needle bar, put the guide back on,then tightened the allen screw.So much for the problem I have had for months. He said if the guide did not want to see in I could put a touch of glue on it. I think it going to be alright without.
Apr 30, 2008 | Brother XL-3510 Mechanical Sewing Machine
Kodak EasyShare M1033 Digital Camera Logo
178 people viewed this question
Top Kodak Cameras Experts
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
