Question about Sharp Televison & Video
Need Parts for sharp Lc32av22u / SN 704827112 A
I had a surge on my lc32av22u sharp tv. I took it apart and found a blown 6.3a 125v slow blow fuse and a blown capacitor with the numbers 10e241 72p fe on it. The numbers on the IC board for these components were F401 and CP413. Does anybody know where I can get these parts from?
  • 229 Answers
Hi, here you can get all that you need :
http://toddstoyz.com/cls/index.php?searchStr=LC-32AV22U&_a=viewCat&Submit=Go
ae me please
Posted on Jul 30, 2010
I went to Radio Shack to buy my open 6.3 slow-blow
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Apr 28, 2010 | Panasonic CT-36SX12 36" TV
Keeps Blowing Fuse
You obviousely have a short somewhere. Take it to a repair place.
May 26, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Sharp LC32AV22u does not turn on
press the on button on the remote and see it with the help of mobile phone's camera. If u did'nt see a light coming out of the remote, then your remote is faulty.And if u see light then your tv sensor is faulty.
cheers
Sep 10, 2008 | Sony RM-V310 Remote Control
In order to hear the sound, on our 32" (LC32AV22U) TV, we have to turn all the way up. Is there a way to increase the sound? We are not hard of hearing.
do you have a cable box connected? is it same when playin a dvd on difeerent inputs? i founded alot of motorola boxes with same problem.if thats the case you would need to change settings on the cable box.
Jul 02, 2008 | Sharp Televison & Video
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Nothing works
The fact the set blows up the correct fuse is because it has a short ahead in the circuit,it could be one of the diodes(4) that is shorted,if one of these guys is bad all of them should be replaced with the exact replacement,ahead of them it should be a regulator and he is bad (shorted) it could have taken the diodes and the main fuse.The cause might have been a power surge.If you are familiar with tv service you can check the regulator and the diodes before you put in a new fuse,if you are not too familiar be safe and take the set for an estimate.If you suspect power surge or lighting damage it might not be worth repairing.Let Us know if you need more information.
Oct 26, 2006 | Sharp 25N-M100 25" TV
Open Questions:
Did I install the t-con board wrong? I was having flickering on my sharp aquos and replaced the t-con board. Now I get no picture. After I thought the new t-con board (verified exact same part, ordered on tv parts today) was defective because I got no picture after installing it, I decided to swap back to the original t-con board. when I did that I still had no picture. Which made me think I installed it wrong. I undid the cables, reinstalled the ribbon and the menu appeared on the TV when turned back on. So that made me think something wasn't set right w/ the ribbons when I installed the new t-con board. So I swapped back to the new one, and after trying to make sure I set the ribbons correctly, I still have no picture. So then I went back to the old t-con board (because as I just verified, it was working after I re-installed it the 2nd time) and now I STILL have no picture. I swapped back and forth a couple more times and I can't get any picture to show up. So that makes me wonder did I possibly fry something (I was very careful, kept myself grounded, didn't get rough w/ the ribbons, etc) or is it something like the ribbons are just extremely sensitive and maybe they're still not set right (they're very hard to reach)? Any thoughts on how I could test the t-con boards to check if they're good and I didn't blow something? I saw a video that it's possible w/ a multimeter but I'm not sure where the fuses are on the board or which area to test. Thanks in advance.
Jan 15, 2019 | Sharp Televison & Video
Televison & Video Logo
449 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
