Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F & P Dishdrawer DD6031
Both drawers have started turning on by themselves apparently in the rinse cycle, (though nothing happens) the motor just whirs. The drawers aren't locked and the red indicator light is on on the front display panel. This continues no matter what I do until I turn them off at the power switch.
Alli
    New Friend:
    Problem Solver:
Hi Alli,
Were you able to fix this? I have the same problem.
James
james.vial@fivestar.edu.au
Posted on Dec 21, 2014
  • 4 Answers
The Problem is Related to the Dishdrawers Motherboard Control Center This usually happens when water condensation sits on the board to long and Short Circuits controls.
Posted on Aug 07, 2009
  • johnloschiav Nov 05, 2010
    well what do i do if the board short circuits and were is the board
Wont rinse or spin
I think your washer's drive belt has broken, Joanne. You'll need to have someone replace it. That's a pretty easy fix, but they'll need to know your washer's model number before they arrive so they can bring the correct belt to fit it.
Aug 06, 2014 | Indesit Washing Machines
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Wont start. Starter tries to engage but theres a "whirring" noise instead of the car starting
Sounds like starter solenoid is failing to kick in. The whirring is most likely the starter motor turning, but the teeth aren't engaging on the flywheel ring gear due to failed solenoid.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jan_ed8272c8c2968d14
Jan 12, 2012 | Hyundai Elantra Cars & Trucks
Loud whirring noise going into rinse cycle. Low
Hi tuck just read your posting.Now on the low whirring noise on the start of the rinse cycle ,Is it when the machine is draining the water or filling with water.If the noise happens when the machine is draining then I think either your pump has something slowing it down or it is faulty.Please look underneath the machine to the front right and you should see a red or black fan .If you do then this is your pump.If you don't see a fan you must have the newer style of pump.Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Cycle starts, continual humming, no wash, no movement, just humming noises. Have to stop the wash.
If it hums from start, and it is filling fine from inlet valve, then the problem is usually timer control board or motor control unit board/motor failure.
If it gets stuck on filling forever, check also the pressure switch.
Parts must be tested before replacement.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Zanussi ZWF12070 Front Load Washer
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
I turn on my maching and the door locks, but nothing else happen
I had the same problem within my 1 year warranty. I called the company and they sent out a repairman. Apparently, there is a magnet in the drawer that lets the machine know the drawer is closed and it is safe to start the cycle. If the magnet isn't there the machine doesn't think the drawer is closed and won't start. The repairman simply had to replace the magnet and the washer started after that.
Apr 13, 2009 | Frigidaire GLTF2940ES Front Load Washer
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
702 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
