Question about Canon i860 InkJet Photo Printer
Magenta and yellow ink not printing on test print
  • 39 Answers
Print head is probably plugged. With caution (this can ruin your printer if you get too violent) take a Q-Tip wet with rubbing alcohol and touch the printhead where the ink tranfers to the paper. To get access to the cartridge open the cover and when the carriage moves to the center unplug the printer. The alcohol may soften the dry ink enough to get it printing again. If it starts printing again do a print cartrige cleaning with the software included with the printer.
Posted on Jul 11, 2009
Mix-it-up
  • 832 Answers
SOURCE: Not printing too well
Do use genuine brother ink for testing: If you're lucky the filter in front of the nozzles (which is part of the printhead) is not clogged. Do the power cleaning twice: power up. push menu then start mono then four times arrow up. machine will display maintenance. push arrow up several times til 7 is displayed then Enter then arrow up til 6 is displayed. Push Enter. push arrow up til 3 then Enter: P cleaning_all Push start/mono. After machine has finished maintenance will be displayed. push arrow up til 0 (zero) then enter then puh arrow up til 9. machine will print a test sheet. Repeat procedure above if no good result. After three times without success the printhead is clogged due to wrong ink. ...and do use dye-ink only for brother printers (pigmented ink will clog the filter!)
Posted on Sep 14, 2007
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
Posted on Jun 14, 2008
rulds2008
  • 3866 Answers
SOURCE: epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 23, 2009
SOURCE: Printing below standard
I GOT IT!
FOLLOW THESE INSTRUCTIONS,
note: the star before the 2,8,6,4
that's why i couldn't get into maintenance mode earlier.
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode
Posted on Sep 08, 2009
SOURCE: hp deskjet F4180 prints wrong
I had the same problem and the solution I found was to uninstall and then reinstall the printer driver. For some reason this worked. I now get the correct colors.
Posted on Dec 20, 2009
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
Even with new inks, magenta and yellow won't print
The ink you replaced costs as much as a new printer that comes with ink. Get a new one.
Aug 27, 2012 | Epson Stylus 2200 InkJet Photo Printer
My CX4900 printer only will print in magenta &
plz check printer alignment & printer ink stuats, is that possible other ink were not active.
Nov 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
194 people viewed this question
Clive
Clive
old marine
old marine
