Question about Saeco Odea Giro Espresso Maker - Black/Silver
I turn on the machine Odeo Giro and the green thermometer flashes for a while. It then goes steady but at the same time the red heater light and the full basket light alternately flash. - no joy....
SOURCE:
SkinWill
  • 148 Answers
SOURCE: Red alarm flashing
The flashing indicator light means something needs to be refilled or emptied.
Posted on Oct 15, 2008
SOURCE: My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Posted on Apr 10, 2009
SOURCE: We've descaled and the light still appears on the
Have you done as described in the manual:
Press the hot water button for
6 seconds to deactivate the
descaling light.
Posted on Aug 16, 2009
  • 6 Answers
SOURCE: Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
Posted on Jun 26, 2010
SOURCE: Water light is flashing - Saeco Magic de Lux
Running the water out of the steamer for about half a cup of water fixed it for me
Posted on Mar 24, 2013
Can I replace the grinder in my saeco odeo giro?
yes see the next steps. and fix it. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the HEATING ELEMENTS and the switch, thermostat, and timer .
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Oct 15, 2012 | Saeco Odeo Giro Automatic Espresso...
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
I have a new Saeco Odea Giro Coffee Machine and have turned it on for the first time. I followed the instructions but the red alarm light is flashing and no "steady flow of water comes out of the wand". I...
Is it the red light flashing and the water button light also on? That means air in the system.If the flow of water is not steady, make sure water tank is fully push in.
The next thing you can check is the test mode which is not given in the manual.Hold down water button and switch on the machine,you will see the lights turning on alternately in anti clockwise direction. Release the button.Turn the dial to the right and press the coffee button, water pump will work.Turn on the steam/water knob and keep pressing the coffee button until all the air is purge out. Dial on other positions will test other components of the machine,such as grinder, solenoid valve , brew group,etc: I hope you can solve your problem with this information.
Feb 15, 2010 | Saeco Odea Giro Plus Coffee Maker
Our machine has stopped working....the alarm light is on and flashing slowly so we have gone thru all the steps in the book to find out what is wrong. When we turn the machine on, the green lite goes on...
If red light slowly flashing....Please check brewunit,dregdraw, door and coffeebean lid is properly in .
If flashing fast..means ventilate(prime the machine)
If itis steady..no water in the tank or time to empty the drip tray.or the more serious case the grinder is not working or not self testing.
Nov 17, 2009 | Saeco Odea Giro Plus Coffee Maker
We've descaled and the light still appears on the saeco odeo giro
descaling light.
Jul 18, 2009 | Saeco Odea-Giro Espresso Machine
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
See all Saeco Odea Giro Espresso Maker - Black/Silver Questions
Saeco Odea Giro Espresso Maker - Black/Silver Logo
75 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
