Question about Black & Decker Saws
Adjusting depth of blade
How do I adjust the depth of blade
  • 2,176 Answers
Generally you dont adjust depth of blade, you buy the blade in different lengths to suit the job and material
Posted on Jul 17, 2009
Blade wont cut all the way down when cutting baseboard
the maximum cutting depth of a circular saw is the distance from the teeth to the drive washer hub of the saw blade
so on a 7 1/2 saw the effective cut would be less than 3"
if your base board is thicker than that get a bigger saw
it the board is a lot less adjust the cut depth adjustment for the saw base
Nov 19, 2016 | Saws
How to fix depth adjustment knob that won't turn on PC186CS Circular Saw
Try to work the rubber cover loose and squirt in a couple drops of gorilla glue and reinstall. If that doesn't hold, try contact cement on both pieces and let dry and reinstall. That will really grab each other in a rather permanent way.
Jun 17, 2014 | Porter Cable Portercable Pc186cs 18v...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
How do you lower and raise the blade on my d364 circular saw
There are typically two adjustments on the saw, both of which operate with a wingnut type of screw/bolt. The one in the front of the saw adjusts the angle of the blade (typically front right hand side of saw) and the second, to the rear right hand side of the blade, adjusts the depth of cut by moving the bed (flat part of the saw on the bottom) up or down.
Jun 20, 2011 | Dewalt Saws
We have Skil 7 1/4 circ saw model 5400-01 how do you adjust blade depth?
There is a lever on the back of the top blade guard, if you pull up on it you can adjust the foot up or down to control how deep the blade will cut.
Oct 16, 2010 | Skil Xdrive 7 14" Circular Saw Ships Fast
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
Blade Depth
Aren't there two handcrank wheels on the sides of the saw? One is for blade angle of cut, the other is for depth of cut.
Jun 07, 2010 | Craftsman 10" Table Saw
I have a DeWalt DW733 and I need instructions on how to change the knife blades. Is there a jig or something to set up the blades.
Are the blades turnover knives? If they are the easiest way to do it is to adjust the planer bed or seat to omm planing depth. then take either an adjustable (combination) square or steel rule, and hold the edge of it along the bed or seat and adjust the allen (Hex) screws so that the edge of the knife allows a piece of a4 paper to pass between it and the rule tightly. Do this both sides of the knives and you are done.
Jul 07, 2009 | Tools & Hardware - Others
Saws Logo
148 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
