Question about JVC HD-56G886 56" Rear Projection HDTV
My tuner has quit working. All other inputs work okay. TV is 4 years old. Is is worth repairing? If so, what is neede to fix it?
    President:
  • 788 Answers
Your symptoms sound like the tuner has just stopped working. I have replaced tuners in sets for years and the repair is not the difficult if you have a low wattage soldering iron, I would recommend a 45 watt iron.
I know if may sound simple, but the tuner is a small silver box inside the set on the signal board that is replaced as an entire unit. I usually remove the signal board to remove the tuner and install the new one, just be careful with the circuit board while it is out.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to a person and get a status on price and availability.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 11, 2009
Vizio flat screen tv has no sound. Everything else is okay. How can I fix this.Mute is off
First, be sure it is the TV & not the source. Try a known working source & see if you have sound. If not, you will need the Main pcb unit. That is the one with all you input/output ports.
Sep 01, 2014 | Televison & Video
No longer has picture - voice still working - can it be fixed or is it worth fixing?
Not knowing brand and model number most of these sets have a 4-5 year life and parts for a set of this age may not be available.
The risk in repairing a set this old is it may just fail again and again.
Dec 23, 2012 | Televison & Video
LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
May 16, 2010 | LG 32LB9D TV
I cannot get my directv box to work on channel two and three. I can get the game input to work for dvds and games. I also have switched boxes and the they both work, just not on the emerson tv.
It sounds like the tv tuner on the emerson has gone bad if the directv box is not working on channel 3. Try channel 4 on the emerson tv and see if it works. If not you may consider using the game input for directv and disconnecting the dvd player or game console and then reconnecting them only when you use them. You would need to disconnect directv from the game input each time to use the dvd player or game console. Oterwise for simplicity buy another tv. not worth repairing these days
Jun 06, 2009 | Emerson EWF2004 20" TV
Old TV and old DVD player
Make sure your TV is "tuned" to the proper input. To change the input, change the TVs channel below 02, find the "input" dialoge on the tv's menu, or press the "input" or "video" button on the TV or Remote.
Repairing a 20 year old VCR (By chance a BetaMax?) is not worth your time. Replace it with a $60 DVD/VHS combo unit.
Mar 12, 2009 | Televison & Video
11-year old Mitsubishi VS-6043 picture flickers and bends
check for cold solder joints on the yoke connector located behind the speaker grill and mounted on the crts. You may also want to check for cold solder on the vertical output i.c.
Jan 08, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Ghost switch
Hello!
Your tv has bad solder connections at the tuner and microprocessor or you have a bad eeprom IC...or both. The eeprom IC is to the tv what ram is to your computer...memory. The tuner's RF shield\ground connections and the microprocessor's RF shield connections must be soldered. If the solder job at the tuner/micro has already been done then replace the units eeprom IC and your set will work.
Sounds like not an easy fix ,huh? It's actually very easy if you have any experience soldering. I did about 5 a week for 8 years or so. Every RCA\GE tv made between 1992 and 1996 needed to have their tuners and micro's shielding\grounds re-soldered. There was a class action lawsuit brought against RCA for this.
If your unit made it this long without having this repair done it's amazing...the problem was cracks would appear in the solder ( cheap solder ).
If your unit has had this service done...most had to be carried out when the sets were only 2 to 4 years old... then your sattelite technician recreated the problem just by unscrewing\screwing in the input cable to your set. He broke loose the solder connections again.
If your unit has good solder on the tuner and micro then replacing the eeprom IC will get your unit exorcised!!! Good luck! Please rate my solution...Thank you!
barneyluc
Oct 20, 2008 | Televison & Video
Sharp 34" TV
Why shouldn't it be worth fixing? It's only 4 years old, my own TV is 15yo, I fixed it twice but it's still kick'n! You have a problem in the power supply, do you have electronic's know how? And test equipment? Soldering equipment? If so we could walk you through it, If not A repair man should only cost 80 to 100 to fix it.
Aug 13, 2007 | Sharp 32C-240 32" TV
JVC HD-56G886 56" Rear Projection HDTV Logo
193 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
