Question about Altec Lansing ATP 3W Computer Speakers
Speaker problem hi my atp3 works fine until recently when the left speaker started to have fuzzy sounds and i could barely hear any sounds aside from the fuzzy noise.any suggestions?
  • 749 Answers
Check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Posted on Nov 15, 2007
GE 29385 Corded Speaker Phone
Something in the affected telephone's circuitry is failing.
Dec 29, 2013 | Lands Phones
2006 pontiac g6 sound problems
That, my friend, is in your balance system of the radio itself. Check it with other speakers you know are good. You'll see what I mean.
Nov 28, 2017 | Cars & Trucks
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Mar 07, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Speakers
If I understand you right, you have 7 speakers on 7 different channels.
When you have just 1 speaker connected it sounds fine, but any time you add more speakers it shuts down, or does it sound fine until you have all 7 of the speakers connected.
Bare with me, and we will figure this out. It is a very diificult job trying to troubleshoot something that is not in front of you.
After this post, it will be about an hour or so before you will hear from me again, I will be on my way home from work.
Is this a 5.1 surround system or is it listed as 7.1?
Do have have any speaker outputs with more than 1 speaker connected to it.
If this is a 5.1 system, do you have speakers connected to the "A and "B" speaker jacks?
What kind of speakers are they, and do they say on the back where you connect the speaker wire what ohm rating they are. Most speakers for your home are 8 ohms.
in case you were wondering what a 5.1 and a 7.1 system is:
the 5.1 system has front right, front left, center, rear right, rear left and the .1 is for the sub-woofer that is normally a RCA jack output on the back of the receiver
The 7.1 has all those same speaker outputs plus it has a surround back with right and left channel.
I will get back to you in about an hour or so.
Jun 23, 2008 | Audio Players & Recorders
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Help
maybe you should check the configuration of your built-in sound card.
Jul 04, 2007 | Altec Lansing ATP 3W Computer Speakers
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
May 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3 volume control/power know gone bad
hi i used to have the same problem opening the satellite speakers of atp3 (left satellite, the cord was pulled and snap from the inside). i found out how to open them but there's a good and bad news. the good news is i know how to open them, the bad news is that it will cause some damage on your satellite speaker.a friend of mine used to have the same speaker he accidentally drop one of his satellite speaker (left one) and the bottom cover just crack open following the joint line.
the satellite speakers of atp3 has no connecting screws , it is assembled using a sort of super glue. here is how i opened my satellite speaker.
i used a flat screw driver (i sharpened it a bit to easily penetrate the joint) to shove the bottom cover of the speaker starting from the back part (near the cord) then slowly made my way around when the cover start to snap from where i started. you can remove the bottom cover this way but be aware that it will cause some damage on you speaker. i started shoving from the bottom back part because the damage is unnoticed when you reassemble it using a super glue and i use a black paint to hide the discolored plastic casing cause by force opening.
i hope this help a bit
J3n c",)
Mar 26, 2006 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
140 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
