Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My tv screen starts normal then fades gradually The tv is working, but all I get is a black image
    Problem Solver:
  • 6 Answers
Check filament voltage to picture tube. Connector on CRT board may be loose.
Posted on Aug 31, 2009
  • Toshiba Master
  • 1,650 Answers
Check the CRT ground wiring. I saw this on a computer monitor after I forgot to reconnect the wire from the ground line around the picture tube. It would start normally and fade out over a period of five-fifteen seconds.
Caution: pull the plug and wait several minutes, then check for voltage between the bare wires around the outside of the picture tube and chassis ground before you put you touch anything. If you get voltage, this is definitely the problem, and I've just saved you from a nasty shock (could be almost as high as 2nd anode voltage). If you don't get voltage, inspect at will.
Posted on Aug 28, 2009
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
Display fade out
replace bad inverter board for screen back light.
Sep 03, 2012 | Polaroid 3211TLXB 32 in. LCD Television
I have a sony kdf50we655 TV. Over the last 12 months, the picture has been increasingly "pixelating" with royal blue dots. It started with the lower right corner of the screen fading from black...
This is not a LAMP issue, it is much more serious than that, you need to have it checked by a certified technician, it sounds like the image prossessor
Jul 27, 2011 | Sony Televison & Video
KDL-40S2000 horizontal black lines
Seems T-Con board mounted at top center at rear of LCD Panel is bad.
Local TV tech will fix TV by replacing T-Con board.
Thanks.
Aug 30, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
Color loss
Your formatter or what is called the FMT board has bad capacitors on it.
May 23, 2008 | Mitsubishi WD73727 73" HDTV
No picture only sound
The bias supply to the CRT may be failing, or the CRT itself is failing. It is difficult to detemine without going in to the set and taking readings, and diagnosing the exact things that are going on.
Jerry G.
Apr 19, 2008 | Televison & Video
Nokia 6030 screen fading
only slightly damaged lcd screens can take affect once there is a litle crack heat builds up on the screen and you have to repair it
Apr 02, 2008 | Nokia 6030 Cellular Phone
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
