Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Can you move a freezer with frozen food across the country
  • 1,305 Answers
Yes, here are some helps:
1. Buy a load of dry ice and pack as much as you can in the available spaces of the freezer. The less free air space the better.
2. When traveling, if at all possible when stopping for the night, use an extension cord to plug the freezer in.
3. You may need to repack the dry ice once, but you'll be in pretty good shape if you fill it tight.
You may want to seal the door shut with tape. Avoid duct tape...too much residue .. try gaffers tape, it can stay on for a few weeks without leaving all the duct tape goop...
Hope all goes well on your trip.
K
Posted on Jul 13, 2009
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
What is the suitable temperature for 3 star freezer in uk summer?
3 star freezers are not storage freezers and will maintain frozen food for a short time only, They should reach -18c when closed but may come up in temperature quite rapidly when the door is opened. They are usually found as the cooling evaporator in fridges with freezer boxes in. Four star freezers are dedicated freezer storage space and will keep frozen food at the right temperature for some months.
May 19, 2012 | LEC Freezers
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
The hose that allows water to flow into the ice cube tray is frozen. is this keeping my water from flowing out of the door
You'll need to get a blow dryer and then thaw it out so it can flow again. Move your frozen foods into the fridge while you do this. Let me know what happens. I might have another few ideas. Raz
Apr 14, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Food is only frozen on bottom shelf
dkburing,
You said, the freezer is only keeping the food frozen on the botton of the freezee. It is cold, but only like a refrigerator.
We need more info,
What is tour brand,model number and the year or age of the fridge.
Waiting for your reply
Huuum
Oct 09, 2008 | Freezers
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
540 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
kfinlay1969
Level 1 Expert
AJMAL KHAN
Are you a Danby Freezer Expert? Answer questions, earn points and help others
