SOURCE: Frigidaire side by side doesn't make ice
If the Temperature in the Freezer is not cold enough, the Ice maker will not make ice. Make sure the freezer is below 10 degrees or so. Zero is where you want it for the best ice production. What was the reason for defrosting in the first place? Should be frost free?
SOURCE: My side by side Maytag fridge
There shoud never be ice built up in the bottom. The problem is thatthe defrost drain water is not getting to teh pan underneath. If it were coming from the icemaker you would have a colum of ice from the icemaker area down the back wall... like a stalagtite. It still sounds like you just need to clean the tube that goies from the inside bottom of the freezer to the drain pan with a turkey baster and hot water
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. [email protected]
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
SOURCE: GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
SOURCE: Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned
off. Here's how to check. Look for a wire along the right side of the
ice maker that looks a bit like a coat hanger. If this wire is in the
raised position, the ice maker is turned off. On some units you simply
lower the wire to the down position to turn the ice maker on.
On others,
you lower a small red plastic lever to lower the wire. If the wire is
in the proper position check the freezer temperature, it should be
between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the
ice maker may not produce any ice.
Check your door seals and thermostat,
repair/replace as necessary.
Thanks
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
