Question about ASUS M2N-MX Motherboard
Audio problem sound is not coming from front panel. all the wires are properly connected.
  • 661 Answers
Here is a copy of the manual
here is the section on front audio output/input
audio problem - a98e426.jpg I hope this information helps
Posted on Nov 15, 2007
  • Gareth Cockram
    Gareth Cockram Dec 18, 2007
    not sure that this is inappropriate information.
Audio Problem :- Motherboard - ASRock N68-VS3 UCC
Windows 7 has sooo many different options for audio it is confusing. If you right click on the (windows) speaker icon in the system tray and click "volume control options" you get one set of features.
If you click on the "sound" icon in the device manager you get entirely different results!
And lets not forget that your sound card probably has its own audio configuration utility!
I have found that sometimes you have to play with all of these programs to get the sound to work properly.
Getting windows to recognize the "default" seems to be the biggest issue.
Oct 15, 2013 | ATI Asrock N68-vs3-ucc Ddr3 All-in-one Am3...
How do i connect my reciver to my lcd hdtv so the audio is coming from my speakers not the tv speakers.
kindly get four audio RF connection wires look for the audio output on the front or back of your tv. one of the output connection is white the other is red.look for the same connectors on your reciever the same colour.but they are marked input.plug the output wires from your tv to the input connection of your reciever.if you have separate speakers, connect the speaker wires from the output connectors of your reciever so you can get sound comming from your tv through your reciever,good luck.
Sep 25, 2011 | LG Televison & Video
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
My front panel audio and microphone doesn't work
try to check the connection on the board wether its proper if no then check the manual of the board it will help u also check the setup in the bios also there r setting in some program of the sound software check this should solve the problem thankyou
Nov 16, 2010 | ASUS P5KPL-AM SE Motherboard
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
ASUS M2N-MX Motherboard Logo
526 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
