Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Our Kenmore side by side is not cooling at all on either side. The compressor is REALLY hot and the fan is not turning? Where should we start?
  • bellsy2 Jul 11, 2009
    It may be too late? We note that the compressor is thermally protected - does that mean it shuts down automatically and how does it re-start?
    Further my previous issue with our Kenmore fridge...compressor hot, fan won't turn on....we've mucked around and cooled the compressor and plugged the fan back in....now the fan turns in reverse and won't cool the compressor.....HELP
    Problem Solver:
  • 8 Answers
Check power going to condenser motor, but been the fact that compressor is runnig, the fan should be running also, so looks like you will have to replaced the motor
Posted on Jul 11, 2009
  • KitchenAid Master
  • 3,361 Answers
Replace the fan motor. Turn it off until the fan motor is replaced or you will burn out the compressor.
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore side by side compressor keeps getting hot
Your fan is stalling which in turn is over heating the compressor causing it to shut itself down. Replace the fan and make sure the coils under the fridge are clean. That should take care of the problem. Good luck
Dec 29, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Refigerator not working properly
the compressor is out of coolant/freon.u should not run it if the compressor is too hot to touch
Aug 02, 2008 | Kenmore Elite 21086
OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Jul 03, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
131 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
