Question about Refrigerators
I cannot find the drainage pan to get the fish smell out of the refrigerator the model number is 59669872990 with a bottom freezer it is a Kenmore refrigerator.
    Problem Solver:
  • 8 Answers
You cant remove the drain pan on this model, is got a hot refrigerant line running on it to evaporate the water from condensation
Posted on Jul 11, 2009
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Freezer freezing up in the bottom vents, the fridge is not cold enough. the freezer works great. there is no drainage in the drain pan in the bottom. it is a frost free refrigerator.
The heater for the frost-free isn't functioning. Have a technician check the circuitry on the heater for breaks, or even a defective heater!
Feb 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Smell and where is the drain pan
Find the Drain pan, it collects water and smell like sh**. I located the pan on my fridge, and proble solved it was undet the motor,
good luck
Nov 09, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
