Question about Maytag Dryers
How do I shut off the very loud end of cycle sound in maytag ldg8506AAM gas dryer
  • 525 Answers
This buzzer is non-adjustable. Click the link below, provided by, www.repairclinic.com to view this part so that you can identify it in the control panel of the dryer. You can remove the wires from it to make it inoperable. You can also get disassembly instructions at their site.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
http://www.repairclinic.com/Appliance-Parts?s=t-ldg8506AAM-%3d%3d&n=5
Posted on Jul 12, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Dryer gas heat not staing lit
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Dec 30, 2009 | Maytag LSE7806A Top Load Stacked...
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't heat
i only ask this because you mentioned the loud noise are you almost out of propane, is it a pop sound or ?
Jun 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Maytag 5806 Gas Dryer starts and suddenly stops.
You may have a problem with a thermal overload sensor. Since it runs and then shuts off, this sounds like the problem.
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
96 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
