Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
Type of oil used in ac2001 air compressor - Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
  • 142 Answers
It should take any standard compressor oil, available and Home Depot, Lowe's, Sears, and auto parts stores
Posted on Jul 11, 2009
What kind of oil do i put in my clark 4gal pancake compressor
If it's an oil-less, none. If it's a regular compressor, use compressor oil.
Jun 02, 2012 | Clarke Power Products Inc AC2001 2HP 4...
Ac2000b motor runs but builds no pressure in tank
Your compressor is worn out. It is repairable but you will quickly find out that the price of the rebuild kit and S+H is about the price of a new compressor at your local store.
Oil-less compressors cannot stand up to use and abuse they get like a oil compressor can but they are certainly affordable.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Where can I but a replacement Capacitor for the Clarke AC2001 Air Compressor
Hi, my name is John. Welcome to FixYa. You can get it here www.mastertoolrepair.com .Thanks for choosing FixYa...John
Nov 20, 2010 | Clarke Power Products Inc AC2001 2HP 4...
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
My Clarke AC2001 4 Gal. compressor hums when power button is up. Compressor will not start up! Why?
one of a few things possible, first is that the start capacitor is faulty, second could be the start switch inside the motor, and the third that the pump is not unloaded ( if only happens when the tank has air in it) or the pump and or motor is locked up.
Mar 23, 2010 | Clarke Power Products Inc AC2001 2HP 4...
I need a drain plug for a Clarke Air pancake two horse compressor. Model AC2001 Serial # 1005188 Where can I locate one? Dan
Master tool repair is a good web site to get things like that, they sell a lot of generic parts like that
Dec 29, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Oil type for air compressor
You can go to any Home Depot and buy compressor oil for your compressor. Your operators manual should tell you what the level should be, however if you don't have one, filling it with oil until it fills the glass tube about half way should be sufficient.
May 16, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Oil covering pancake and pressure adjustments
Typically on the inside cover of the electical box it will illustrate the cut-in/cut-out controls. There should also be a fill port above the pump end of the compressor. Do you have a sight glass on the side of the compressor *(around the area of the leaking oil) usually if its coming out its due to overfilling or tipping over of the compressor.
Feb 02, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Oil problem
All reciprocating compressors have a series of pistons that pump up and down inside their individual cylinders to compress the air to a higher pressure. This rubbing creates friction, which creates heat. In order to conserve the life of the pump, you need some type of protection. Some pumps are “splash” lubricated with oil and some have a teflon-type lining in the cylinder. Oil-less compressors are adequate for lighter use applications and have the advantage of being able to run off-level without worry, however even though they are considered low-maintenance, they tend to wear much quicker due to more heat build-up and repair costs could be extensive. Oil-lubricated compressors have the advantage of keeping the pump running cooler and lasting much longer and are built for the professional who takes pride in ownership and will maintain his equipment. However the key is to make sure the compressor sits level so the “splash”-lubrication is effective and reaches all cylinders. If run off-level, it can score the cylinder and do heavy damage over a short period of time. It is very difficult to claim warranty for the owner in this case.
Aug 27, 2008 | Clarke Power Products Inc AC2001 2HP 4...
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
354 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
mikenearman
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
