Remote control codes for Sanyo TV
I am looking for the code(s) for a Sanyo tv, that I can enter into my remote for the RCA DTA800 converter
jay196969
  • 41 Answers
SOURCE: RCA RCA311B Remote Control
i also have the same remote and t.v. i found the codes on this website
http://support.rcaaccessories.com/doc/aud1744.xml?docid=810&Referring%20DocID%20List%20Index=4&navtypeid=6&pagetypeid=2&prevPageIndex=4&selectedmodel=RCR311B&selectedFamily=generic
Posted on Dec 17, 2007
aprmaejun
  • 97 Answers
SOURCE: RCA RCR311W Universal Remote Code for LXI TV
From what I can tell, it could be any of these codes:
1000
1006
1048
1049
1062
1072
1073
1100
1109
1130
1162
1181
1203
1212
1233
I used this website:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
Posted on Jun 12, 2008
SOURCE: RCA DTA800 programming codes
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
Posted on Nov 11, 2008
SOURCE: I have a ILO TV and need the codes for a RCA DTA800 converter
Already found solution with codes from Orian that worked.
Thanks
Posted on Jan 06, 2009
joboo1
  • 257 Answers
SOURCE: Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
Posted on Feb 08, 2009
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
Sep 30, 2014 | Televison & Video
I have a RCA Digital converter box remote that needs to be programmed for my TV and I do not have the code or know how to program it manually.
You have a limited number of TV brands that can be controlled by this remote as DTV converter boxes are just basic function devices. If your TV is not on the list, then it cannot be controlled. If your TV brand is on the list, look for the 3 digit codes next to your TV brand. You may have to try all the codes if one does not work. You should have the list on a separate leaflet that came with your converter box.
Press PGM on the remote. Enter the 3 digit code with the number keys. Press OK. Test by pressing the volume button and see if it works. If not try another code next to your TV brand from the list.
If you lost the leaflet then here is a link online to see this information:
I'm assuming you have the DTA800 box.
Aug 08, 2010 | Televison & Video
I have a remote control for my converter box brand rca #dta800 but i want to program my control to my tv and i dont have the code.
look inside for the codes to your tv model and it usually is trial and error.
Jun 16, 2009 | Televison & Video
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Dta800 with 1991 Emerson tv
Your Emerson could have been built by Funai who now owns the name rights in the US.
Try any codes you might have for either of that name.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Jan 27, 2009 | RCA 3-Device Universal Remote
Thanks
Jan 04, 2009 | Hitachi 57F510 57" Rear Projection...
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Jun 19, 2008 | Televison & Video
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
