Question about Nikon COOLPIX S200 Digital Camera
No pictures All pictures taken are black. However the screen works, as all the menus are displayed properly
Re: no pictures
This is a CCD sensor ( see enclosed pic of one taken out of Canon camera from my workshop ) problem and this is why you will be able to play back pics that were captured properly but cannot capture new ones : the CCD sensor is not outputting anything at all.
Not all bad news because Nikon replaces these free of charge so contact your agent ( if you have this done by independent repair outfit it may be uneconomical to repair on this entry level model ).4e7add3.jpg
Posted on Nov 15, 2007
0 characters
3 Points
LCD Screen
Your camera is working exactly as SLRs have worked for the first half-century since their invention. You frame the picture through the viewfinder then take the shot. The display is for menu settings and reviewing pictures after they've been taken. Newer DSLRs will let you use the display for picture-taking (and take videos) but the A200 belongs to the previous generation.
Mar 26, 2014 | Sony Alpha DSLR-A300 Digital Camera
Hi there, My camera dsc-w120 used to work fine,just recently when I turn it on there is only the information on black on display, it doesn't show what I'm pointing it at? Do you know why that could be or...
I have a similar problem on my DSC W320 just a black screen when using the viewfinder and when i press to take a picture it is still black. Everything else works fine, I can access menus, change settings, view pictures that were taken before this error. VERY STRANGE, please can you help!!!!
Apr 21, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD880 IS has a black display screen. I cannot take pics now with the black screen, but the display DOES work for pics taken before the screen went black. Please help!
I don't have a solution, but I have the same problem. I found one posting elsewhere that said that this was a "common" problem. That person's camera was under warranty. Mine isn't, but it's less than 2 years old.
Oct 25, 2010 | Canon PowerShot SD880 IS Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
LCD Screen Black/Blank. ? ? ?
Perhaps you have quick view turned off in the setup menus. There's no way the CCD is the problem as the camera takes pictures.
Feb 09, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Jul 22, 2007 | Nikon CoolPix S2 Digital Camera
Black Pictures
Do you have it in manual mode with too small an aperture and too fast a shutter speed?
Sep 12, 2005 | HP Photosmart R717 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
41 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
