Question about KitchenAid KESC308LSS Electric Kitchen Range
Kitchen cooker how to wire it in the wall sockett is there the cooker came with 3 foot of cable thats it no diagram
  • 25 Answers
The green wire is the ground,
the white wire is the common,
the red and black wires are the 240 volts (hot) wires)
Posted on Nov 16, 2007
How to hard wire my cooker
hard wiring requires the services of an accredited electrician
it requires an isolation switch on the wall near the cooker and suitable heavy gauge wiring and circuit breaker in the power board
it is not a diy job
May 07, 2017 | Kitchen Appliances - Others
What am I looking for
Call any other to fix it.
Feb 17, 2015 | Kitchen Ranges
Ive started to wire up a cooker to the maines in the kitchen wall the wires in that are blue yellow and brown but the wires on my cooker are brown yellow and red why is the red one diffrent
By cooker I guess you mean stove/oven. Different makers use different color wires, but if this is a 220 volt unit, you should have two hot wires and one neutral. The hots can connect to either hot, just don't hook a hot to the ground. Use a voltmeter to see which of the mains is hot (if in doubt), and trace wires on cooker to see which is the ground. Easy!
Dec 15, 2014 | Cars & Trucks
Inside wiring diagram for 2001 34 foot Golden Falcon Park Model
Request the wiring diagram from the manufacturer.
Oct 27, 2017 | RVs
Wiring diagram for my creda concept solar plus cooker
Request the wiring diagram directly from Creda.
Feb 23, 2018 | Crock Pots & Slow Cookers
I have a belling cooker switch that has had 3 contacts welded together, i have ordered a new switch but where can i find a wiring diagram to check the conecction for the new switch
have a belling 862 and the grill switch will not regulate can anyone tell me the type of simmerstat that is required?
Jan 15, 2009 | Kitchen Ranges
I need to wire up the electrics on a gas cooker
the oven should have a flex already fitted, this will need to be plugged in or connected in to a supply ensuring it is correctly fused, i suggest no more than 3 amp.
Oct 05, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Wiring diagram
In the UK, to connect to the connection block of a fixed integrated oven in a Kitchen, you must be a Part P Registered electrician. Such an electrician will issue a Minor Works Certificate for this work on completion - otherwise they are not Registered!
Be aware that if the work is not done under Part P and a fire occurs, etc your insurance company are entitled to REFUSE to pay out for the damage including any consequential damage to neighbours property or for loss of life!!
The block has three terminals and the Live, Neutral and Earth are indicated by marks stamped on the metal back of the cooker (if a CE product).
L = Live and takes the Brown covered wire
N = Neutral and takes the Blue covered wire
52080c4.gifor E = Earth (CPC) and takes the green/yellow covered.
If the cable has an uncovered copper third wire or is coloured Red/Black it should be replaced from the connection accessory on the wall behind the cooker with a heat resistant 3-core Butyl cable of sufficient size to cope with the load of the oven.
If you let me know the rating of the oven (label on door) in amps or watts, I'll tell you what size of cable you need.
Apr 13, 2008 | Hotpoint RB526 Electric Kitchen Range
KitchenAid KESC308LSS Electric Kitchen Range Logo
250 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
