Question about HP NX9010 Notebook
Nx9010 screen very dark
When I switch on my laptop the screen is very dark and I cannot do any work. I can connect it up to a monitor then it is fine. It is quite old and no longer under guarantee. Would it be advisable to get it repaired?
    Brigadier General:
  • 6,966 Answers
Based on your post/description that the laptop still works using an external monitor, then perhaps what is at fault is your laptop's display. Chances are that it is the CCFLamp (Cold Cathode Florescent) that provides that backlighting or even the inverter that powers it. In some extreme case, it is the LCD display screen itself that is at fault. You can verify that it is the CCFLamp/Inverter by shining a flashlight at the darkened screen while the unit is operating. Some semblance of your desktop would be visible albeit too dark to be of use.
If indeed you have verified that it is the screen backlight that is at fault, it is, from a technical point of view reasonable to repair. Your concern would be local availability of the replacement part, cost of shipping (if otherwise) and local qualified service personnel for the job.
In some areas/regions, cost of repair would not exceed 100USD if it is the CCFLamp and/or the inverter.
Hope that this be of some help/idea. pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 15, 2007
  • Louie  Role
    Louie Role Nov 26, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
    Cheers.
    Sniper:
  • 56 Answers
Ok i am having the same issue with an NX9010 but we replaced the lcd inverter and back light ... took the screen assy off the laptop and put it on another one and it works fine. Any settings maybe to turn off the backlight on this model? or can this be a motherboard issue??
Thanks
Posted on Sep 02, 2008
Why is there no display?
hi
can you plug in another monitor to the video plug on the side of your laptop?
if the monitor works but your laptop screen stays dark your laptop screen needs to be replaced .
If the monitor is also dark then the LCD screen is ok but the inverter needs to be replaced
25717570-m35oz4jvdfvvmght4a51n0jl-5-1.jpg lcd connect to laptop
25717570-m35oz4jvdfvvmght4a51n0jl-5-3.jpginverter
25717570-m35oz4jvdfvvmght4a51n0jl-5-10.jpglcd screen replacement
cheers
May 28, 2015 | Toshiba Computers & Internet
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Screen on compaq nx9010 is darkly,barely visable, machine works otherwise. Restart and no problem (yet?) Is this the ballest going out? Is this circuit part of the motherboard or on a separate circuit...
1) Is of all we will go to BIOS screen and check if we get the same screen.if that the case then we need to take the laptop for repair
2) we will go and install the upgraded graphic driver
3) we can try doing system restore
4) we will go and do recovery
Dec 13, 2009 | HP Compaq nx9010
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Averatec N1000 dark screen
yes what u need to do is that connect the external monitor with the laptop and if works fine with the external monitor then what u can try is that uninstall and reinstall the video driver and ten restart ur comuter and still if that doesnt work then replace the lcd screen...
Jan 25, 2009 | Averatec 1000 Notebook
Acer laptop has developed a fully dark screen
I am assuming that you have tried switching from external monitor output and local monitor. There should be a hot key on the keyboard to switch it. Also, try looking to make sure the driver for the display is up to date. I f it was update recently try rolling the driver back. If you need help with doing any of this post a comment. Hope this has helped some.
Dec 02, 2008 | Acer Aspire 3680 Laptop
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
HP NX9010 Notebook Logo
538 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
