Question about Avaya Definity 6424D+ Phone
Loud continuous tone
I had unpacked new 6424D+ phones.
When I plugged them onto a used port, I hear a continuous loud tone.
I had tested with few new ones with the same problem.
I can not compose any number.
If I put back the old one, there is no problem
I think that there should be something to do on the phone, but what ???
can you help me with it ?
  • randall210 Nov 16, 2007
    Thanks Priority1 for your answer.
    I had an Avaya PBX and 64xx phones.
    I tried to swap between 2 6424D+
    I had finally found a solution of my problem.
    On PBX, I had created Refresh Terminal Parameters feature. On an other extension, I had called this feature followed by my non-working extension.
    After the reset, my phone was working fine.
  • 201 Answers
If you are replacing a 6424D+ with another 6424D+ it should work. If you have more than one phone doing this, there must be something else going on.
You cannot use the 6424D+ on anything else other than a Definity phone system. They will not work at home or on any other phone system (even other Avaya phone systems)
You cannot connect more than one definity phone to a single jack. Each phone needs it's own set of wires back to the control unit.
Do you have a Definity phone system?
Posted on Nov 16, 2007
contact phone line provider ask them to test your line for a corroded connection or water ingression.
Jun 15, 2016 | Lands Phones
My BB9000 is not loud enough. I selected the profile "loud" , selected the "classic ring tone phone", set the volume to 10 and I can hardly hear the ring tone. Thanks, Victor
Did you put your own ring tone on there? If is not loud enough. I know this from previous experience. When you record one and drag into the mini sd card you have to do it very loud. You can use the recorder that comes with that phone and record one and then select it as the tone but make sure you get it close to the mike.
Nov 05, 2010 | RIM BlackBerry Bold 9000 Smartphone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
It has low ring that i can not hear it ringing
The ring tone volume on the X1 is not very loud you will just have to choose a loud ring tone that will catch your attention. Have you tried putting both the phone and ring tone volume up by pressing the speaker symbol at the to of the screen and putting both sliders up full.
Jul 18, 2009 | Sony Ericsson XPERIA X1 Smartphone
Nokia 6300 not loud enough
Hi.This problem may occur when the file is compressed or converted.Like if you compress a file from 20MB to 5MB, its quality gets degraded n ultimately sounds bad.
Other remedy may be to try using the same file in some other format.And just see the difference.
Please keep updated about this.
Dec 13, 2008 | Nokia 6300 Cellular Phone
Message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Sep 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Lands Phones Logo
200 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
