Question about Modems
Modem instalation problem
We are instaling a internal modem of motorola it is giving error code 10
  • 37 Answers
Re: modem instalation problem
try configuring the modem on port com2 instead of com1
Posted on Nov 15, 2007
0 characters
3 Points
I need to download a Win7 Motorola SB5102 cable modem driver via this XP laptop
Yes, you can do it.
Downloading the driver will result in a file you can copy over to the flashdrive.
Just do not double-click on the file, because that will start the installation process.
In the unlikely case that the file auto-starts the installation process, you will normally have the option to Cancel the installation.
May 07, 2014 | Arris SB5102 SURFboard Cable Modem
Hi i cant access to the internet . error 633 please help me
This error means The modem is not installed or configured for Dial-Up Networking. You need to check for modem driver in your device manager and if not present do install it
Apr 10, 2011 | Arris Chipset 56K V.92 PCI Internal...
Need to change password
After some research, I don't see in the manual where there is a password set up function. Did you set one up when you initially installed the modem? There does not seem to be any internal configuration done with this modem. All the settings were on the computer that is attached to the modem. Please clarify.
Dec 23, 2010 | Arris SURFboard SB5101 Cable Modem
Have the driver disk handy and let the computer re-detect the modem. If it doesn't find it, remove the modem from the slot it's in and insert into another slot. the re-detect if it doesn't see it on boot up. It the computer still doesn't fing the modem, you may have a bad modem.
May 27, 2009 | Arris (FMMOTV92PCI) Modem
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Getting stuck on last step of software install motorola sb5120
i dont know. pls solve it yourself darling. Dont give it up...............
Jan 11, 2009 | Arris SURFboard SB5120 Modem
i want to download driver for motorola modem
Aug 29, 2008 | Arris SM56 (SM-56-PCI) Modem
I HAVE SOLVED THIS PROBLEM. before installing this driver uninstall all motorolla driver. and install only charging driver.
after then install the driver file named 'moto_w230_gprs.inf' (available on internet) on same port on which charging driver is installed yhen write the code" AT+CGDCONT=1,"IP","INTERNET" in extra initialization string on modem. (internet is access point network) use another if u have other networks
set the baud rate of ur modem 230kbps
write the user name andf password
and fone number '+cgdata' without quotes and then try
i have cheked on telenor pakistan its working fine
Best Regards
Engr. Tarique R. Memon
Aug 05, 2008 | Modems
Installation cd
10-step total networkingLINK:
Apr 16, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Motorola 5120 Surfboard
Yes it can happen after a reinstall.. You will need to go into the computer ie take the back off. Pull the modem out and put it back in in another slot exact to the one you pulled it out of. Try it again it will no doubt read this time.. It can only be done this way if you try to manually install a moderm it will load the standard one NOT your Modem. Goodluck!
Sep 05, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Modems Logo
76 people viewed this question
Top Modems Experts
Brian Sullivan
Brian Sullivan
Are you a Modem Expert? Answer questions, earn points and help others
