Question about Shimano Cycling
How do you change the rear tire with the shimano nexus 3 speed derailleur system
  • 74 Answers
SOURCE: Shimano 105 front derailleur does not change down
Try lubricating the cable and housing. If it has much resistance then it will not operate correctly.
Posted on Apr 13, 2009
  • 37 Answers
SOURCE: Shimano top swing front derailleur fitting - help
Go to Parktool.com it's real easy. good luck
Posted on May 26, 2009
  • 74 Answers
SOURCE: I need a manual for a Shimano nexus 3-speed hub
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302052334&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=1248577311531
scroll down to Nexus
Posted on Jul 26, 2009
  • 636 Answers
SOURCE: shimano 70gs rear derailleur won't shift. The
Is the cable still attached ? have you tried adjusting the cable?
  • 6 Answers
SOURCE: Shimano Tourney rear derailleur is stuck on
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Posted on Aug 30, 2009
How do you adjust a shimano xtr m9000 front derailleur from 3 speed operation to 2 speed operation as there is no selecter switch
You have to do it at the front derailleur. You adjust either the inner or outer limit screw so that the derailleur can only go to two of the chainwheels. Front Derailleur Adjustment
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Feb 24, 2017 | Shimano Cycling
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
Trying to figure out how to remove rear tire from 26" inch hyper shimano bike. Would help if i could get an online manual
Any search engine would take "remove rear bicycle tire" and produce many good answers. Involvement of Fixya experts is an unnecessary and delaying step.
Aug 04, 2011 | Shimano 09 Xtr M971lc Mountain Bike Rear...
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Cycling Logo
179 people viewed this question
Top Shimano Cycling Experts
Arturs Kalnins
Arturs Kalnins
rigger094
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
