Thermostat reading My thermostat automatically changed to celsius and I need to change it back to fahrenheit. Please help!
    New Friend:
Push up and down at the same time
Posted on Sep 14, 2013
  • 44 Answers
Inside of most stats there is a switch that changes for F to C. some stats you have to into the installer set up program to fix it. if I knew what kind of stat i could maybe walk ya through it.
Posted on Jul 12, 2009
Thermostat changed to Celsius without out us changing it. We have had this thermostat for several years without any problems. Reviewed the manual and checked to see if the original install was set...
Check the dip switch (3) it should be in the on position...It may have moved when you mounted the thermostat on the base. Also check batteries you are using...long life alkaline only.
Feb 25, 2015 | Honeywell CT3200 5-2 Day Electronic...
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
My thermostat now reads in Celsius. How do I change it back to Farenheit? IF80-54
Try the following, Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Jan 06, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a Robert Shaw thermostat and it converted to celsius degrees. How do I program it for farenheit???
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°Ÿbutton for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°Ÿbutton to switch the display.
Jun 16, 2010 | Shaw Robert RS-9420 Thermostat
AC Thermostat
If you have a maual go to the installer settings, Most manufacture have these manuals online
Mar 21, 2009 | Heating & Cooling
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
252 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
