Question about Whirlpool ART535 Top Freezer Refrigerator
Full of ice, no deforst , I change the timer and it seems to work, but after somo days start again, the model is WRT18DKL , i think is the termosthat but i need to know how to check it.
    President:
  • 1,136 Answers
Hi, You will need to check continuity on the bi-metal switch and it needs to be tested while cold. If the bi-metal has an open circuit, it will need changed. Remove the rear inside panel of the freezer and locate the bi-metal switch at the top of the evaporator coil.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 11, 2009
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Fridge/freez ,motor fan stopped power going in,lound buzzlike a transformer
manually trun the defort timer clockwise until the unit goes into deforst mode. IT MAY BE THAT THE EVAPORATOR COIL IS FULL WITH ICE.
Jan 31, 2012 | Refrigerators
The deforst timer didn't work and got ice
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Jul 15, 2009 | Whirlpool ED5FTGX Side by Side...
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer works, the refrigerator does not
check out for the refrigerator setting, plz keep the setting in high,, else check your compressor,, thank you plz rate me,,,
Jul 07, 2009 | Frigidaire FRT17G4B Top Freezer...
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Freezer does not freeze some items completely and ice maker not
Replace the defrost timer. Take your make and model number to appliance part store and get a defrost timer. Relatively cheap and usually easy to change...
Jan 04, 2009 | Amana Refrigerators
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
Whirlpool freezer and the refrigerator.
Chances are your defrosting clock is stuck or quit working.
The clock works as timer to set time for defrost, at which time it stops the compressor, and turns a heater tube next the cooling coils to melt ice. It depends on your expertise if you want to try replacement,as most replacement are universal, and some rewiring is sometime involved. The clock is usually in front at the bottom behind the removable grill, or in the back. It looks like a square box with a dial that has a one way turn knob. To check use flat screwdriver to slowly turn dial (you can only turn one way) until the compressor stops, then wait to see if compressor starts back on it's own (it might take as long as 30 min.).
If it does not start it's bad and need replacement. Of course you can turn dial again until it starts again so you can use fridge. If it does start it could still have been the problem where the clock got stuck, and you got it going again by turning the knob, but let it run. If it works for a while and then have the same problem again the replace clock.
Hope this helps you
Dec 12, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Whirlpool ART535 Top Freezer Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
