Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer just stops in middle of cycle, flashes f. keeps happening
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps stopping in the middle of a cycle and i keep having to hit the start button. what is the problem?
How old is the washer? Older washers used contacts inside the control module (typically an enclosed unit) and over time, carbon builds up on the contacts and eventually, good contact cannot be made anymore.
Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
131 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
