Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn air 2388DT evap coil frozen over
This happens to me about once every six months. The first two times I had a service guy out, he swapped the heating element and the defrost control board. The third time I bought the parts on-line and did it my self. By then I had the nagging feeling that swapping the parts was having no effect. The next two times I just did a manual defrost with a hair dryer. That gave the same result: about six months til the next problem. My guess: the defrost just gets "behind" or something and can't catch up. I dunno, seems like a design flaw. But, it sure is cheaper to do a manual defrost twice a year. not the end of the world.
  • fixya441 Jul 12, 2009
    tommyboy - thanks for the idea. But, I replaced that each of the first three times. Each time it helped for about 6-12 months, then the same failure repeated.
    Problem Solver:
  • 8 Answers
Most likely is the defrost heater, this type of unit are known for having this type of problems, it has a dual glass heater, check the bottom one,hope this help!
Posted on Jul 11, 2009
Freezer on and off
Could be a couple problems. The thermostat may not be making the contacts close to tell the compresser to turn on all the time. The compresser could be overloading which would be caused by overheating (clean the condenser). The freezer and frige evaperators may be becoming frozen up due to a bad defrost timer. When the freezer warms up check to see if the compresser is running, if it is not put your hand un it, if it is hot then it's overloading and should be replaced. If it is running and isn't really hot check to make sure all of the fans are running, should be one condenser fan and one on each evaperator. And look for ice build up inside the freezer and fridge. If all the fans are running and coils are clear and compresser is running next st is a plugged cap tube which is the metering device to the evaperators. The mechanic can trim them down six inches and fill the system and they should work great again. Hope this helps
Sep 06, 2012 | Jenn-Air Refrigerators
Water Leaking from Freezer Side of Refrigerator
Got a couple of questions before we can really say much Does the refrigerator/freezer appear to be running as normal? is it perhaps always running at the time the water leaks for longer or more noisily than normal. Is the temperature of the freezer as normal? is there a particularly cold patch in the refrigerator , probably at the back or on the freezer side near the bottom? Where exactly is the water leaking from? and is there water collecting inside? Does the door seal properly at the base where the water seems to be coming from? Is there another major appliance with a heavy current draw that always goes on at the same sort of time? I'm thinking a water boiler, or aircon/heater, or the oven etc. Please post back, and we can start running through possible solutions :)
Jun 28, 2007 | Jenn-Air JCD2389G Side by Side...
My Jenn Air JCB2285HES not cool on both sides not frozen line
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Freezer works but refrig has 60 degree temp .evap coil is caked
Hi: Did you check the defrost heater itself? I checked Jennair and Sears parts to no avail. If you didn't check the heater it will be at the bottom of the freezer behind where you removed the back cover. A glass tube with a coil in it. If the coil or tube is broken replace that insead. I hope I helped, Jeff I found a website with the defrost timer, but not the location of the timer on the fridge. http://www.appliancepartsworldwide.com/store_SearchResults.aspx?S=1131392&ST=PBM
May 31, 2009 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JCD2389GE Side by Side. My problem is that at random times (once, twice a week and sometimes once every two weeks) a puddle of water is on our tile floor just in front of the freezer...
You have a frozen defrost drain. whenever the unit goes into defrost, usually once a day the water instead of running down the drain is running out on the interior and then onto your floor.Fairly easy fix if your game?
  • unplug your refrig
  • remove all food from interior of freezer
  • remove shelving
  • remove 2 screws holding the rear cover in place these are usually painted white to blend witht he cover. btw this is the lower cover so you do not have to remove icemaker or dispenser bucket.
  • once cover is removed defrost all of the ice that you see with a hair dryer
  • once the ice is gone you will see a drain hole in the center beneath the cooling coil ou need to flush hot water thru this hole to clear any ice and sludge that may be in the line. ( I sometimes have to use a syringe or turkey baster filled with hot water to forcefully clear this line)
  • reassemble in reverse order
If you have any further questions or comments leave them here and I'll get back to you. Thanks Peyton
Feb 23, 2009 | Jenn-Air JCD2389G Side by Side...
Coil a frozen block of ice 1999 Jenn-Air JSD2374ARW
The most likely cause of the problem is the defrost timer. It's job is to cycle the heaters for the coil on and off at intervals, possibly every six hours the heater should come on for seven to fifteen minutes. The timer is easy to replace and you may find a schematic online if you google jenn-air.
Dec 20, 2008 | Jenn-Air JCD2389G Side by Side...
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Jenn-Air JCD2389G Side by Side Refrigerator Logo
245 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Jose Pino
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
