Mac os 9.1
Yea I accidently deleted a file on my IBOOK and now when I start it up it won't boot up all the way all you see is a file folder with a ? symbol and a face looking thing that keeps on flashing back and forth from one to the other and I don't have the original os 9.1 CD so please help me.
  • 121 Answers
Get a new os cd and reinstall it
Posted on Nov 15, 2007
My screen is blank with a folder in the middle
This is an icon indicating that the iBook G4 cannot locate the bootable Mac OS X volume on the hard drive.
Here is a procedure you can use in order to get back to your main desktop:
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
If this does not work, it could mean the Mac OS X directory on your iBook G4 may be damaged or corrupted. So the best step you can take to try to correct this without losing any data from your Home Folder(s) is to run an Archive and Install, with your Mac OS X installation disc.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory no longer in the way of interfering with you accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X
Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary
hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network
Settings, to preserve network and Home directory
settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be
sure to run all Software updates to bring your new
Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If you don't have a Mac OS X installation disc, let me know.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iBook G4 Mac Notebook
It will get to main screen and freeze up
Boot it from the installation DVD. Run a few utilities. If it freezes up, you have a hardware problem. If it doesn't freeze up, you most probably have damaged the OS, and should reload the OS using "archive and install" to preserve your user files. Since this is a Clamshell, I should mention that these are the recovery options for OS ; OS 9 requires a different approach.
Sep 16, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
Clamshell Ibook restore cd's I need everything
The clamshell ibooks came with either OS 8.6 or OS 9 on them. If you are just looking to start over from scratch, then you can use a standard OS 9 CD and have them do a complete re-install. I say this without knowing the nature of the problems they are having.
Jan 29, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Replaced HD on ibook Clamshell, now can't boot
The Clamshell iBook 366 doesn't officially support Tiger, but can usually be installed using 'XPostFacto'. (You can get it here http://eshop.macsales.com/OSXCenter/XPostFacto/
It's open source software but you still might find some aspects of Tiger don't work.
Jan 12, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Computer won't work & shows a file icon w/a"? and a smiley face"
the "?" and the "smiley apple face means it couldnt find the osx to boot from. this can be cause by a bad or deleted file or a failing / bad harddrive. it sounds like a bad harddrive since it doesnt find the destination.
Dec 30, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
MY SCREEN WONT POP UP
You will probably need to reinstall OS X. The simple way is to pop in the disc and boot while holding C on the keyboard. You did delete system files, so why would you expect it to start? There's a chance that you can reinstall OS X without destroying all your information. Just make sure you chose correctly when you start the process.
First though, you might just try repairing the disk. Try using THIS SITE to do so. It should walk you through it.
Nov 12, 2008 | Apple iBook Mac Notebook
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
