Question about Kenmore Washing Machines
Fl reading . cycle starts and stops within the first minute
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
Nov 26, 2009 | Maytag Washing Machines
My kenmore elite reads fl and stops working,
Flood Condition:
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer won't drain
Flood Condition:
Mar 20, 2009 | Kenmore Washing Machines
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Washing Machines Logo
32 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
